Didn't think this project through enough...ideas?
lee
I have started building a chest that is heavily inspired by British campaign furniture. It will sit on a table(yet to be built), will be somewhat movable because its going to be heavy, having nice inset chest handles on the side. Two doors on the front and a drawer underneath. The doors open to reveal a desk gallery with drawers and pigeon holes etc. My twist to the project is that the drawer at the bottom will either flip down or flip up, and i will pull out a tray that will have my laptop sat on top of it.
Now this is where I am kinda stuck, and 'didn't think this project through enough' because I am well into it now.
So like i said there is a drawer at the bottom front, lets say I flip up this drawer front, its on hinges and is really a false drawer front, revealing my laptop sitting on some nice frame and panel tray. I then pull it out, but I want it to be able to then pivot and sit at a slight angle out from the cabinet onto the table. I am probably not explaining this too well, so forgive me.
Drawer slides wont work at they will extend out from the cabinet parallel to the table top.
My tolerances(space) is fairly tight here so I am not keen to use some store purchased piece of hardware .
Think Machinist chest, and how they have that panel that moves on hinges, but also slips back into the chest.
I want the tray to pull out then pivot down towards the table top.
I thought about two stopped dadoes ran in to the sides of my case, then gluing some dowels into the back sides of the pullout tray. The dowels would run in the dadoes until they hit the stop(end of the dadoes) with most of the tray now outside of the cabinet, it would then pivot down towards the desk. There would be some kind of ledge on the panel front to stop the laptop slipping forward.
I am worried that this method may bind? and that pushing the tray back and forth just wont feel smooth.
Has anyone here built anything like this?
I would very much appreciate any ideas and comments,
Thanks
Lee
Re: Didn't think this project through enough...ideas?
John in NM
I've built two things like that - first was rebuilding a water damaged, dry rotted machinist's chest. Second was a drawer for a keyboard in a Parsons style table.
I did the front of the machinists chest roughly as you describe, a stopped dado, but I made little brass dowels to ride in it. As I recall they would spin in the holes at the bottom corners of the front a bit, so they didn't bind. Or perhaps they just didn't bind anyway. The dado was open at the back for installing the front, and then it was captured by the back of the chest.
The keyboard drawer had a front that simply folded down using standard butt hinges. The front was taller than the drawer, so the bottom of the back pressed against the bottom of the drawer when folded down, providing some support. The idea was that the client would glue a wrist pad to the inside of the drawer front, but I don't know if he ever did it.
When you tilt the panel down...
Gary Smyth
does it rest on anything? If you have a laptop on it and plan to use it in that position, how much weight will be on it in the tilted position? What of the height for a sitting person or is it a stand up desk?
Example shows field desks. Can you make the stays extend past horizontal? You could use brass, or I've seen leather straps (like horse reins) too. The leather strips had holes on either end and were pushed on to rounded "ball" end brass dowels drilled into the cabinet and top. You might hide the stays in a false side or an outside pocket
I'm sure others may have ideas, but failing to get a workable solution for what you describe, could the drop down (tilt) laptop holder be incorporated into the unbuilt table rather than the cabinet? It could have a slide out panel (false drawer front) and be supported from underneath with polished brass rods housed in or attached to the table legs. If so it might have the advantage of being more comfortable for typical typing. You could build it without messing with what you have already and would still have the full benefits of the desk above for all the other stuff accumulated at any work station.
AZ in Colorado Springs
Perhaps you could build an inset panel into the shelf that slides out, so when it's open the back of that panel rises. You'd have some wedged pieces glued underneath (on the inside of the case bottom) toward the front and some wedged pieces glued to the underside of that panel at the back. When you pull the shelf out, the back end rises up.
Found another example
Gary Smyth
If the tilt down top is anchored on the case higher, a fold down desk surface with the proper hinges can be tilted beyond horizontal. The top can be anchored to the case as shown on the picture. A laptop adds a lot of weight and hands typing adds more so the front probably has to have something hard to rest on.
Re: Found another example
Joseph Mulherin
I think this last example by Gary would be the sort of campaign furniture that would be used in the earlier century by the General, Colonel or Captain to keep his records.
Measurements would help if you, Gary, could find and post them for us here on WC.
Wish I could help further but no measurements
Gary Smyth
Ralph,
Photos come from a general web photo search under "campaign furniture desk". I also searched "machinist tool chest". There are examples of the fold down being about 1/2 way up a chest. This might provide ideas for the computer shelf. I have no idea if any would be helpful to Lee's situation given that the chest is well underway. His request is for suggestions and ideas. My reply is to show images of other peoples work to serve as possible assistance. I'm attaching web photos and no known credits for the pics shown.
Re: Design It Robustly
William Duffield
However you attach and support the writing surface, design in extra robustness. Not only does it need to absorb its own weight and the weight of the laptop, arms and shoulders, and probably a mouse, but the dynamic act of typing adds a lot of additional forces. I mention the mouse because, in my experience, for many drawing applications, built-in trackpads are useless, and a supplemental mouse and mousepad will be added to the arsenal. Modern trackpads are being made touch sensitive. People have a tendency to strike these even harder than they would push a keyboard or mouse, just because they learn if at first it doesn't do what you want, just hit it harder.
William Duffield
brass dowels
If you are worried about binding, you might try replacing the dowels (or pins) with router bearings. If you position two bearings on each side of the tray at different heights, then you can cut two tracks in each side of the case, so that the rear track rises as it gets to the front end of its travel, dropping the front of the tray a controlled amount.
More complicated to understand but more flexible: Use one track with a "y" at the front, so the front bearing follows the lower leg, and the rear bearing follows the upper leg of the "y". Once you've figured it out, you will realize that if you push the tray back in a bit and then lift and pull, the front bearing will follow the upper leg of the "y", allowing you to access the contents of the drawer below without folding up the laptop and pushing the tray all the way back in.
No need...
John in NM
The single track & stepped brass pins worked fine for me.... why make it more complicated?
Maybe for Lee's project this would be an improvement, if some kind of angled surface is desired. As for binding, it strikes me as a solution in search of a problem.
Re: No need...
William Duffield
You're probably right about bearings vs. pins, but it depends on the material selected for the track. Bearings could reduce the wear on the track over the long run. OTOH, depending on your "campaign," they could get clogged with desert sand, increasing wear on the system. :D
Re: Wish I could help further but no measurements
Joseph Mulherin
Thank you, Gary, I liked the first picture you posted and probably will try to copy for myself and another for two grandsons.
Surely...
John in NM
A campaigning officer would issue his batman a dental pick to keep the bearings clean! :D
Joseph Mulherin
Am thinking I will use mostly 1/4" plywood inside the frame, but the outsides will be 3/4" poplar.
This will give me a good chance to start using the Sketchup program I have saved for quite awhile.
