Quick question. Can I paint the surface OF 1/4" TEMPERED HARDBOARD. Will a quick coat cause it to delaminate? I want to roll on some eggshell white (latex). Just surface. Edges will be covered. Shop application. Just want a basic seal to keep frosty mugs. shop liquids, from causing a moisture swell. If not paint for initial coat other sealer and then white on top? Poly? Shellac?
I have painted it for several applications with water-based gloss and semi-gloss paint with no ill effects. I'd think that oil based paint would be even less able to cause mischief.
Fortunately (or unfortunately) I have a lot of experience w/ tempered hardboard.
Way back when, I covered an entire stage with it. Since then it has been painted numerous time. No delamination at all.
I made sacrificial tops for all of my shop counter tops out of tempered hardboard. For those I just used oil/polyurethane/mineral spirits. They have held up well over the past 10 years.
When I started work in the factory I retired from, many of the (small electrical/mechanical parts) assembly benches were covered with 1/4" Tempered hardboard. Some were painted with oil based paint, some with oil based Poly. I never saw any delamination, even after some were worn down 1/8" by the sliding of the parts. I don't think we ever used a water based paint though.
