200+ woodworking book reviews
Add 2nd. tank to a compreesor?
tom
Has anyone added a 2nd. tank to an air compressor? I have a 30 gal. but would like to have more air capacity when I do small sandblasting jobs.
Re: Add 2nd. tank to a compreesor?
John Foster
It does help. Make sure you use connecting lines of sufficient diameter. At work we have extra tanks at the far ends of long runs to give more reserve and give a more consistent pressure.
don stephan
Discussion a few months ago showed there are differing opinions as to draining air compressor tank. If you are on the drain often side, don't forget to install one on the second tank.
I once added an "effective" second tank to a pancake compressor to run framing guns at a farm building far from power. The extra capacity was in the form of hundreds of feet of air hose! (The real goal was to minimize the voltage drop from a series of 100 ft extension cords!)
The extra capacity did let us fire more nails before the compressor cycled but of course, it cycled longer each time so the average was about the same. In this case, we spent plenty of extra time measuring, cutting, and fitting boards so there was a net improvement.
If your typical use of the sand blaster causes the compressor to run continuously now, I suspect the extra tank wouldn't help much as if the duty cycle allowed more inactive time.
Money better spent on new compressor
Re: Money better spent on new compressor
Tom Dunlap
I had an empty 100# propane cylinder and extra copper tubing for my add on
Before adding the extra capacity I couldn't run air tools continuously Afterwards the compressor would keep pace with all the useage.
This was much cheaper than buying a larger compressor for occasional useage. I really would have liked to buy a larger comp though
air tools and sand blasting are way different
Dick Coers
Sand blasting is like cutting the end off the hose and letting the compressor run. Sure if you use a die grinder or air nailer, a supplemental tank can help. But sand blasting takes hp and tank capacity!
Joseph Mulherin
Why do sandblasting when soda blasting is much cleaner and leaves a smoother surface.
Your present compressor would handle it just fine....and the product could be sifted and cleaned up for reuse if needed. Harbor Freight has a nice unit at a small enough price.
Keith Newton
Yes, another option is to add another compressor. I've hooked two compressors to the same airline to boost the supply. I don't think there was any drawback, unless one got turned off, and higher pressure from the other ran backwards through the regulator. Although I'm not sure that is a real problem.
distrbd, ken
I just recently added a second tank to my Makita MAC2400 Big Bore compressor, The old one was an 8 Gal.Campbell/Hausfeld that wasn't worth saving or spending the money for a pressure switch etc so I just dismantled it and saved the air tank .
The most important reason it worked as an auxiliary tank is, the Makita has a big motor but a small tank, on its own it takes less than a minute to fill from empty, adding the tank only increased the refill time (by 40 seconds )to a minute and 40 second,the point is, there will not be a lot of wear and tear on the new compressor pump.
Adding an extra tank to an already big capacity compressor is different story though, it will have to pump twice as long to reach the cut off point which MAY cause the primary compressor to wear out prematurely due to long refill periods.
I have no regrets adding the tank ,I can also use the extra tank separately as an air pig , roll it to my car or inside the house if i need a bit of compressed air.
Aren't those relative terms
Dick Coers
Like calling a Makita compressor "big bore"? Sounds like marketing to me! Big bore to me is a twin cylinder, two stage, 7hp, 80 gallon tank.
Re: Aren't those relative terms
distrbd, ken
I agree with your definition of "big bore" but that's what they call it, to me is just a name to differentiate that model from the the others.fills up the 12,5 Gal very quickly.
Adding a second tank to a small compressor makes more sense especially if the pump is efficient enough to handle a second tank,in the case of MakitaMAC2400, that pump could be considered as overkill, similar compressors with similar tank size have smaller less efficient heads.
It depends....
John in NM
On first, how big a tank you plan to add, and second, how much that tank is going to cost.
We have a ~200 gallon tank on the air system at work, and during the summer we do a job that requires running two air knives at ~50 psi. That tank drains down in 10 minutes or so. Those two tools probably use less air flow than a sandblaster at equivalent pressure.
I don't know what you consider "small" sandblasting jobs. I have a CH 7hp severe duty cast iron compressor, (actually about 3~3 1/2 true hp as it runs on 240 V with a 30 amp breaker), mounted on a 60 gal tank.
A few years ago I had to sandblast the wheels on a van, I purchased a cheap pressured sandblaster kit from HF and used the bags of play sand from the borgs. My compressor would not shut off at all when blasting.
With the unit up to pressure and off, I could start and run the blaster for about 2 ~ 3 minutes before the pressure dropped low enough I had to wait for it to build again. The only thing an extra tank would have helped is that it would have allowed me to spray longer and then wait longer for the tanks to refill!! So unless you are intending to use the unit for VERY small jobs, I doubt an extra tank would help you much.
