Black Cherry Decking
Paul T
Hello All, I have some 24 inch diameter black cherry that I'm going to have sawn for outside decking. Have a couple questions on proper drying and finishing:
What should I coat the ends with after sawing to prevent checking.
How long to air dry (upstate NY weather conditions) assuming rough cut to full 5/4 which I will plane to one inch.
What stain would penetrate and provide protection?
How soon after installation to wait for staining?
Re: Black Cherry Decking
Keith Newton
Paul, any clear finish that you use will break down from UV, and require maintenance every year. Are you sure you want to do that? If you don't use a finish, it will eventually turn gray like any wood.
Why?
I am not seeing a sound reason to use an expensive furniture wood for decking. If the log is any good sell it and buy something more durable and appropriate for the task.
Re: Why?
Bill Howatt
My thoughts too.
If the idea is to have it look pretty forever then it is either a lost cause or a lot of regular maintenance and most likely, both.
Bill
Re: Why?
Paul T
Why?...Up here black cherry grows like a weed. I would consider the logs I have (from a double trunk tree that rotted at the crotch and fell down) to be too good for firewood but not good enough for furniture grade material.
Re: Why?
I was wondering why also? I also wonder about the rot resistance of Black Cherry. You mention the tree already exhibited rot. There are ways to check out the relative rot resistance of wood, but my instinct is that Cherry will rot while you watch. Maybe soaking g it in Bora Care would help, but its water soluble and rain will wash it away.
Re: Why?
Paul T
I recall New Yankee Norm saying cherry is a great wood for outdoor furniture. I have no experience with outdoor furniture and black cherry but I had black cherry logs that have fallen in the woods at least ten years ago that I cut up to get out of the way only to find the wood solid. Yes the outside was gray but looked great on the inside. Also cut down some stumps left by a logger about 25 years ago and I was surprised how solid they were.
to answer your questions
Your "weeds" are going for 2-10$ a bdft in the log delivered to a mill. I would sell the logs and buy some pine heartwood. But to answer your questions....
What should I coat the ends with after sawing to prevent checking...... Must be done as soon as the logs are cut to be effective. I have had poor success with latex paint and good success with commercial end coating wax emulsion. I usually do not coat, nor do most mills. If the lumber is cut thicker than 8/4 I do usually coat.
How long to air dry (upstate NY weather conditions) .....I bought a few thousand bdft of 4/4 and 8/4 cherry in the fall from mill near Vernon Center, NY and stacked it covered and with good air circulation in that area. When I retrieved it early the next summer it was air dried as much as it was going to and hence would have been ready for decking. Drying depends so much on how and where it is stacked that no useful guidance can be offered.
What stain would penetrate and provide protection? none. only paint offers extended protection
How soon after installation to wait for staining? any time, but the sooner the better.
Re: Black Cherry Decking *LINK*
Grant in Iowa
Hi Paul,
I have not used Cherry as an outdoor wood myself, but I am in no position to empirically deny that it might be OK, either. I would note that it is listed as "durable" in wood books that compare it to other woods for outdoor use. I think the criteria is 15 years out doors for that rating. I can say that I have often used Walnut for window frame replacements that will be painted to great effect.
I too have an abundance of cherry logs offered to me. I think the initial horror others speak of is abundance based, and is certainly regional in nature to some degree. We have all heard of pallets arriving made of Rosewood, or similar, which is the same concept. I would be eager to learn of the results of others using cherry wood outdoors. Such info would give me a use for some of the lower grade lumber I inevitably end op with.
My quick googling turned up cautions to not use any sapwood, as it rots much more readily.
I have had great results when I lived in a much drier climate (Sacramento, California) with Penofin marine oil finish on Cedar with significant sapwood content. The product helped me maintain that new wood look for six years, re-coating perhaps every other year. I know Penofin is often the go-to product for other high end deck woods such as Ipe.
Here's a link to the Penofin Marine Oil Finish product:
Regards,
Grant in Iowa
Re: to answer your questions
TomD
I have had great results with Behr super white indoor outdoor latex. As Bill says the right wax emulsion is tops also, but I have had as good results with Behr. I have some oak logs that have been pointing south for two seasons with Behr on them and they are as good as new, not yet sawn. I used soe emulsion I got from a turning place once, it was green and it stained everything it touched and every log cracked, but if you get the stuff in general use it works fine.
Re: Why?
TomD
You know what you have, but I don't generally consider decking to be a junk use of wood. If wood is good enough for decking it should be good enough for furniture at some yield, otherwise you are talking about splinters checks and knots aplenty to deal with when living with it. But the problem is that when it comes to getting wood into hands that will pay for it, often there are no takers. I showed a picture here of a maple that was 30 inches, perfect, 9K canadian of wood in it at 100% yield. They chipped most of it and the rest sat around too big for firewood, but someone took it.
Options
Black cherry heartwood is durable enough for decking. Of the finishing options, I think I would opt for a semi-transparent deck stain. Clear finishes that form films need annual recoating, or else they start breaking down, the film chips, and you have a major refinishing chore on your hands. Stains are essentially pigments in a vehicle, which is more and more water-based because of VOC regulations. But their failure mode is more of chalking than chipping or peeling, so annual or biennial renewal is far less labor intensive.
These are my two cents and do not cover other options such as Penofin or oil finishes. I can't speak to those.
Ellis Walentine, Host
Ellis is right about the heartwood
Dick Coers
You'll have to rip off all the sapwood if you don't want it to rot off early.
