rehabbing windows OT
Jack Guzman from Maine
I am rehabbing all the windows in an old farmhouse. The client wishes to keep as much of the old glass as I can manage to save. Unfortunately panes break while attempting to remove them .I found some old unneeded sashes in their barn that have the same sized panes so I wish to replace broken panes with these.The problem is,these panes are covered with a grayish film. I soaked them in hot water and ammonia. The film was still there. It leaves a rough texture to the glass so I know it is on the surface. A razor removes some of it but not all. The glass isn't perfectly smooth to start with. I have tried mineral spirits,carburetor cleaner and brake cleaner(stuff I had on hand)They didn't do anything. Laquer thinner dissolved it somewhat but there is still a light film left. Does anyone know of a chemical that will dissolve this stuff? I don't believe it is paint.---Jack
Re: rehabbing windows OT
Chuck Kettler
Try muriatic acid (aka hydrochloric acid). If you are not comfortable using strong mineral acids I suggest trying vinegar.
Gary Smyth
2nd the muriatic acid. It is used by collectors of telephone insulators to get grunge off. It will take a while(day or two) and require some scrubbing. Wear gloves, respirator, and goggles. Use all you buy. If not, store in its container by itself. I put a sealed container (I thought) into the cabinet where I stored rattle can paint and other aerosol sprays. After Winter in the cabinet in the Spring when I opened the doors a half dozen cans had opened -- and I had no confidence in what was remaining. The metal seams and/or seals corroded and they released their contents. The cabinet was in a heated room so they did not freeze. The acid is also used to clean the waterline gunk off of boats, but breathing this stuff without protection even out of doors will make you sick. Muriatic acid is sold and considered a "weak" acid, but don't believe it. Use carefully!
I'd Try
some lye-based stripper, like deck finish remover. Wear gloves, brush on, wait 15 min., light scrub with a brush and hose off.
Re: I'd Try
I'll try stripper first if that doesn't work I'll try the acid.thanks ---Jack
Chuck Kettler
It is only weak because it is dilute. Strong acids, like muriatic will dissociate completely. Weak acids like acetic (vinegar) do not completely dissociate. A face full of muriatic fumes will inflict significant damage to mucosa. Be careful.
And a third...
John in NM
Mild HCl or straight vinegar is my first try for cleaning film off glass if standard glass cleaner won't do the job.
I would avoid strong bases like lye myself - as I understand it, a strong base can etch glass.... doesn't do your fingers any good either :D
Re: I'd Try
It on a corner or already broken pane before going whole hog on the lot.
good advice
Re: I'd Try
Ralph Lipeles
I'm with Jack. Try paint and varnish remover then wash using a sponge and detergent and water. If that doesn't work, go to the acid
Re: I'd Try
jerry roberts
I'll Tell you. I went thru just about that about 6 months ago with a very old rocker I was re doing. I tried just about all the things that has been mentioned and nothing worked well. The only thing I had left was acetone. Tried it and it worked very well. Thing is it evaporates fast so I had to get another can but it was worth it. Good luck.
There is one that works...
Mark Hennebury
Hydrofluoric acid......but read the warnings its a nasty bit of stuff, i have used it a few times.
What is on the glass is probably mineral deposits from rain. Hyrofluoric acid will dissolve those and make the glass clear again, but don't leave it on too long as it dissolves glass and metal and just about anything else.
Don't get it on your skin, you wont know if you do... not for a day or two anyway.
https://thechronicleflask.wordpress.com/2013/04/16/the-acid-that-really-does-eat-through-everything/
You can get a diluted solution specifically for the purose that you want made by Winsol laboratories called crystal clear 550
Website:
http://www.winsol.com/550.htm
Youtube video:
https://www.youtube.com/watch?v=YpjFoN-kqIk
Re: There is one that works...
TomD
Is that the stuff that if you get it in your bathtub, along with a dead body, it ends up in hallway below?
Apparently that scene is fake, but the stuff is super toxic and very dangerous to mess with.
I don't have a lot of experience with it, but what about CLR for decalcifying.
Glacial Acetic acid
Which is 99% acetic acid - dilute it a bit if you are spraying it on. If you are soaking, maybe 50/50 GAA/water.
Or as high a concentration that you can get - 30% may work.
You can get it from Amazon - there may be other vendors that will sell you the glacial.
I've often cleaned glass windows with vinegar and newspaper that wasn't printed on. The organic nature of the acetic acid solubilizes some of the organic material. The acid acts on some of the mineral deposits.
You can also try the vinegar and newsprint approach first to see if it budges the film.
Re: Glacial Acetic acid
That is another thing I mighty try. I think I'll opt for new glass before I mess with hydroflouric acid though.---Jack
Mark Hennebury
My daughter said its what they used in the show "Breaking bad" to dissolve "problems "
I first tried it about 25 years ago for glass etching; filled the shop with some nasty fumes, i ran out pretty quick. I switched to sandblasting after that as it scared the crap out of me, it leached under the plastic resist and didn't do crisp lines, and i wasn't interested in working with it enough to work out the problems.
Bruce, a MN Galoot
Long ago in a different job, my secretary was married to a guy who worked at the refinery in Mandan, ND. Refineries use concentrated HF acid to clean pipes - it strips anything. One guy got some HF on his hands and was taken to the local hospital ER. The doctors were unable to neutralize it because it had gotten under his fingernails and was working its way to the bone. He was in such excruciating pain that he told the docs to rip out his fingernails so they could fix it. I can't even imagine that much pain.
Be careful with that stuff.
Mark Hennebury
Where is the sense of adventure Jack?
You can also try diamond polishing pads, they sell kits for polishing scratches out of auto glass.
Hank Knight
Jack,
You mentioned that you have already tried hot water, so what I'm going to suggest may not work for you.
Years ago, I found some really attractive cut glass panes at an architectural antique shop in Memphis. I bought a bunch if them thinking I'd find a use for them (I haven't). They had a greenish gray film coating on them that I had a hard time removing. Like you, I tried lots of things and nothing seemed to work well. I don't recall how this occurred to me, but I found that if I held them in a stream of live steam (I.E., over a steaming tea kettle), the film disintegrated and could be wiped off with a damp rag. It came off completely and left a pristine glass surface. Just a suggestion. Maybe your water wasn't hot enough.
Good luck with your project.
Hank
Muriatic Acid did the trick
I tried Zip-strip, Formby's refinisher,soy-gel stipper and some stripping afterwash. I soaked in vinegar for an hour. Finally I tried Muriatic acid. One part acid to 20 parts water. Two minute soak and I used a chip brush to lightly rub the surface. After rinsing and drying--it worked. The glass is clear. I cleaned seven panes I had to do and it is all fixed.thanks for all the thoughts---Jack
