New Dresser Build
New Dresser Build
New Dresser Build
lee
Well i finally finished my new dresser build. Took me about 6months to build, unfortunately the full-time job just didn't let me get into the shop much. I purchased a lathe for this project and have never used one before. I am quite happy with my first attempt at turning, I've got the bug now. Closer inspection will reveal that both legs are slightly different, as are the frame supports for the blackboard too; but they are close enough.
Its not perfect, but i am quite happy with it. The build is Oak, Cherry, Pine and Birch, basically scraps from other projects. All top coated with chalk paint and a water base finish. Drawer bottoms are ply, as is the back, but everything else is wood. The carcass is mortise and tenon, i think it should last.
Not up to some of your guy's standards, but i have one happy partner.
hopefully the pics work
LEe
www.flickr.com/photos/81029717@N00/29640223435/in/dateposted-public/
www.flickr.com/photos/81029717@N00/29014093774/in/dateposted-public/
www.flickr.com/photos/81029717@N00/29014097394/in/dateposted-public/
Re: New Dresser Build
Lotta work, nice result
Thanks for posting your project, Lee. You talk about standards, and there certainly is always room to take a project to another level, but a big part of the design process is in knowing where the right compromises are. And every design has them.
I recall about an interview about 30 years ago where I was asked about my approach to design. First, there's always a client: it's either you or someone else. Then there's an aesthetic -- in your case it was this nostalgic mirror-on-chest design. And there's a budget, or at least a rough idea of how much you are going to invest in time and materials. My approach was usually to first decide on the best solution, as though the budget weren't important, and then to back off until it was something I could afford to do under the circumstances. The outcome was planned, no apologies needed. The successful design satisfies all the important criteria, and you've been quite successful with this piece. Good work.
It would be nice to have all the time and resources in the world, but we all know how likely that is. Keep up the good work. The dynamic and your abilities change and mature with everything you make.
Re: links won't open for me
Links - Copy and Paste in New Window
John McGaw
The dresser looks good and the design is clever. About the turnings not being identical, don't sweat it unless you ave a duplicating lathe and think that it is malfunctioning. Hand turnings are always just a bit different and unless they are right beside each other nobody but you will ever know unless you allow strangers to get at them with precise measuring instruments. Even production turners will admit that there is just a bit of variation in their work -- nature of the beast. My first dresser included ten hand turned cherry 'Shaker' pulls and I just knew that they would be my downfall but nobody noticed a 1/32" difference in diameter or height and now neither do I.
Lee
Thanks for all the great feedback everyone.
Lee
