Hate When That Happens
So am at the point to start cutting the mortises for my G&G Bandini bench, right?
The tenons on the 1/2" back slats were cut precisely to 5/16" so I could use the 5/16 chisel set in the mortiser.
'Cept I doesn't has a 5/16" hollow chisel set.
"Didn't you check your sets before you cut the tenons?"
That would be silly, I'm sure I have 1/4" 5/16" 3/8" and 1/2" sets.
"Duh."
No Duh, somebody snuck in my shop and stole that &%$#@! chisel set. I KNOW IT WAS IN THE DRAWER!! Call the heat! Activate the National Guard! I've been . . .
Um . . Amazon prime will deliver the new chisel set on Tuesday.
Well, I can do some shop-cleaning in the mean time . . .
Re: Hate When That Happens
Re: You will find it..
Mark Nowicki
... the same day the new set arrives from Amazon.
NO! You will find it.....
minutes after you use the set from Amazon and can no longer return them.
Psst
Guys, I checked the dox on my JBM-5 mortiser. It came with 3 chisel sets, not 4. I never had the 5/16 set. :D :D
Re: NO! You will find it.....
William Duffield
…when you put the new ones away, this time in a safe place where you know you'll be able to find them the next time you need them, and you'll find there is already something there, and it's the missing tools. I can't count the number of times it has happened to me. I figure there must be trolls in my shop, hiding things they know I'll get in trouble with if I use, and then waiting for the UPS delivery truck before putting them back.
Re: Typical behavior...
Mark Nowicki
...of lawyers and politician; repeat a lie often enough until you are convinced it is true. :D
Spares are handy
John in NM
Especially for G&G work. A spare chisel is handy for making holes for little square pegs. Shop I worked for did lots of G&G copies, we put dowels behind the pegs when important, just the peg when decorative.
I more often wear out or break the auger than the chisel (Lately, I do a lot of 9/16" through 4" of endgrain, I've gone through three augers and am still on the first chisel).
Great Minds
I had actually planned on using the 1/4" chisel to cut holes for tenon pegs! Drill a 1/4" hole then punch it with the chisel and glue in the square dowels in contrasting wood.
Had To Prove It
Was convinced (deluded) the machine had come with a 5/16" chisel set so had to go to the manual, which I still have in the plastic bag envelope, to find out there was no chisel that size that came with the mortiser.
Jeesh, it was 20 years ago, and I've only ever used the 1/2" chisel set.
I can't claim credit for it...
John in NM
That was a standing practice in the shop before I got there.
We also glued the square pegs in and then shaped the tops of them. Sharp chisel and a bit of thick veneer to protect the larger surface from the bevel as you quickly cut it to a pyramid and then sand to preferred shape. Some like to shape them before installing, which is fine too - just takes a bit longer and is less risky.
At one point I tried rounding the corners around the bevel of an old chisel, but it still dented the wood (cherry) when shaping the pegs. Just roundish dents instead of bevel corners. Dents usually came out by some magic of the sanding department, but I didn't like to count on that - seemed kinda rude to leave my mess for someone else to fix.
Robin Corell in Atascadero
Ive done stuff like that and then settled on some other way only to find the missing tooling mounted in the machine.
Auger Bit Source
If/when you break one, who ya gonna call?
Re: Auger Bit Source
Got it, Thanks
[the 5/16" set that came from Amazon is made to fit a Delta benchtop. The bit is an inch or so short so all I've got in the JET's chuck jaws is about 1/2" of bit shank]
Re: Almost Worked Again Yesterday
William Duffield
I had misplaced a chalkline several years ago. Tuesday, I was in the Borg to replace a worn out Leverlock tape measure and picked up a replacement chalkline at the same time. When I brought it into the shop Yesterday to put it away, the fault in my plan became apparent. No, I did not find my old chalkline. I should have been more careful in picking out the new one, because I bought one that came packaged with a squeeze bottle of chalk dust. I did find two bottles of chalk dust in the tool box. They were both blue, same as the new chalk. >(
