auction lumber
auction lumber
auction lumber
cameron youngstrom
I picked up 800-900 bf of cherry and walnut from an auction for a really good price but there was a catch. The shop had been unused for several years and obviously some water had gotten into the place, really musty odor. As I was loading up the wood I realized this guy had just stacked his lumber on the concrete floor and the bottoms of the piles were damp. I left the obvious bad stuff behind (lost some really nice 10-12/4 x 10' boards as well as some 5/4 x 12-14" wide stuff. A few of the boards on the bottom had some bark or some cracks that had some kind of white fluffy fungus-type stuff within (I have a picture but am not sure how to get it posted on this site due to needing it on the web...). I figure that is bad and have been cutting those areas out of the boards and am storing them separate from the rest of my lumber. Does anyone have experience with this stuff? Hoping I haven't brought the plague into my shop and basement storage area...
Also, the moisture content is hovering ~12%, I typically deal with kiln dried or very air dried lumber. I have stacked most of this with stickers in my basement and plan to let if dry (already have a big pile of dry stuff so there is no rush on this pile.) Question is this: I've flattened and planed most of the boards that were towards the bottom of the pile and had the white stuff thinking that I'll remove any contamination. I brought one good sized pile down to final thickness before I thought about movement as this stuff dries down... I've stacked this stuff with stickers on my shelf. The 2nd pile I've only planed down to ~7/8". Am I likely to lose the 1st pile? Can/should I bring the 2nd pile down to 3/4" or should I wait until it dries more? I'd like to plane it down now if possible to remove more of the surface material as well as reduce the weight and volume it takes from my shelves...
thanks
Re: auction lumber
Re: auction lumber
don stephan
To some extent, it depends on how flat and straight you prefer stock to be when incorporated into projects. Additional movement as the wood dries to 7-10% is quite possible.
Some feel it's flat enough if clamps, biscuits, dominos, . . . can force flat and straight during glueup; others want each piece of stock to be flat and straight before glueup.
My experience is with kiln dried hardwood, delivered sometimes by enclosed box and sometimes by open flatbed after two hour drive. I stack with stickers for a minimum of 1-2 weeks before rough milling, during which time I joint one surface flat then power plane the other surface parallel. The rough milled stock is then stacked with stickers for at minimum another week. After this adjustment period, only one or two very light passes on the jointer are needed to render one surface flat again; if additional jointer passes are needed, after flattening and making the other surface parallel the piece is stickered for an additional week, and any still not flat after this additional week are scrapped. But this is only one person's method . . .
Re: auction lumber
Any signs of powder post beetle?
Dick Coers
They LOVE damp hardwood!
Re: auction lumber
Re: auction lumber
Sounds like a score, Cameron. Personally, I wouldn't worry too much about the moldy spots, unless they have shot all the way through the lumber, which isn't likely. The mold will not thrive in a dry environment. I would definitely recommend NOT surfacing the lumber to anywhere near finish thickness until it has reached the MC you're shooting for and/or been rough dimensioned. Final thicknessing at this stage only ensures that you'll be making thinner boards when it comes time to use them, to get rid of warps and cups that are likely to develop. 12% MC is in the range of typical air-dry lumber, so it probably won't lose too much thickness with further drying.
Basements aren't famous for being dry or warm, so if you don't have a better place to dry this wood, I'd suggest using a dehumidifier and/or fans around the stacks to help dry them.
Ellis Walentine, Host
PS Register a profile if you'd like to post pictures directly from your computer.
Re: auction lumber
Re: Any signs of powder post beetle?
cameron youngstrom
got a some pieces with tiny holes and bored trails but I suspect this was from prior to sawing the tree, I don't see any bugs or any trails of dust but I will keep an eye out, thanks.
Re: auction lumber
famous last words, "I assume" LOL
Re: auction lumber
Cameron, in my experience tiny holes in lumber are more likely from power post beetles that ate into the wood AFTER it was cut from the tree. They often start in the end grain but can be anywhere. If there are holes, there are likely bugs in the wood which can exit a long time later and infect other wood. High enough heat can kill them but not much else.
You can google power post beetles to see the types and the size of holes they make.
Re: auction lumber
Re: famous last words, "I assume" LOL
cameron youngstrom
Now you've got me worried, I saw the bug trails in some stuff that looks like poplar but seems too light, was more damp than the rest, my wife throw a few in the truck but I left the rest of the pile (was going to toss it but milled it up and thought about using it as utility shelving on some metal shelves.) Didn't see anything in the cherry that I milled up, probably about 100 bf. Thinking the poplar-type stuff is going to hit the burn pile now... Reading on these bugs it seems the larvae can be in wood for 1-5 years, that's a long time. My basement is not really that damp (more older air dried cherry down there is sitting at 6-8% mc) but wondering if I should throw a dehumidifier, apparently the beetles don't do well under 12%.
Re: auction lumber
I have purchased a LOT of lumber from Estate auctions, some with PPB, I have not worried too much about moving it into my shop as the shop is heated and air conditioned 24/7, and wood stored there for a year or so is under 6%.
I have several thousand bf stored upstairs in the shop, unless the lumber is under 6 ~ 8% when I obtain it, I sticker it for a year or so then remove the stickers and stack tight. I have never seen any current action of the beetles (no dross piles), nor any infestation of existing lumber. I don't and wouldn't recommend doing any planing prior to using the lumber as it may move. The only time I have done any is to "skip" plane one surface to see what kind of figure the wood contains.
I have a lot of Cherry, Walnut, Hackberry, Poplar, White Oak etc and smaller lots of misc. woods in storage. WAY more than I will ever use, but my youngest son also likes woodworking so he will have a great supply when I pass on!
Re: auction lumber
It takes heat to sterilize the wood
Dick Coers
The core of the boards have to be held at 135 degrees for hours to kill anything in the wood. It takes an insulated box with a heat source to do that. Lots of experiments on the internet, but none are as proven as the heat. Buying too much wood is the worst mistake I've made. My shop is clogged up with wood that will likely become estate sale material.
Re: auction lumber
Re: auction lumber
Robin Corell in Atascadero
just for comparison I air dry all my wood. I typically mill everything at 2 1/4" thick and stack my piles 12" off the ground and use 3/4" stickers. Depending on the species it is almost always ready to use in 18" months with only a few species needing more time. I live on the inland side of the coastal range in California and the lowest the wood gets is 6-7% around the end of the summer- fall, and then it increases to 11-12% in the late spring. On the rare occasion I buy kiln dried lumber, in a couple of months it is at the same moisture content as all the other wood in my shop.
In areas that get a lot of snow and cold temps in the winter or high humid summers the high vs low moisture content is often reversed with the highest being in the summer and the lowest being in the winter. It can be helpful to have a moisture meter and know how the wood in your shop varies but it really required as long as you follow accepted norms for allowing wood movement.
Re: auction lumber
Here is how I would deal with this. *LINK*
Keith Newton
This is a very inexpensive way for small shops deal with these problems.
Once you've got it hot enough to kill the insects and eggs, if you are going to store the wood in an outside shed or down in a damp basement, just wrapping it in plastic will keep it dry.
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=newarticles&file=articles_946.shtml
