Epoxy Primer Question
tom
This is not woodworking related but thought someone here might have the expertise to respond. I sprayed ,after sandblasting, a bike frame with 2 part epoxy primer. Because the final color has not been selected the base and clearcoat will be done later. We used the bike and where the water bottle leaked it started a bit of surface rust. So my question is does the epoxy only not prevent rust but only when used with the base and clear coats? I re-finished 2 other frames last winter complete with base and clear and no problem.
Thanks in advance for your help!
