Project completed
Project completed
Project completed
Hank Knight
I finished the double chest of drawers I built for my kids. It is dimensioned to fit into an alcove in their bedroom, so the sides and back won't show unless they relocate it. The drawers ride on Blum Tandem Plus with Blumotion slides. The jury's still out on the Blum slides, but I've got them adjusted and they seem to work as advertised. We'll see if they maintain their adjustment. My kids are no-nonsense types, so the design (mine) is pretty straightforward. The only flair is the curly maple.
[URL=http://s50.photobucket.com/user/hankknight/media/Chest%20of%20Drawers/image_zpsmznndnz1.jpeg.html][/URL]
Re: Project completed
Mighty Fine Hank!
Sometimes "simple" in design is tougher than it looks. That is a really sharp piece. Nicely proportioned and the graduated drawers are well done. Kudos sir!
T.
Thank you, Mr. Skaggs!
jessecloud
Sweet! Clean, crisp, well crafted!
Let us know how the Blum slides work out.
Will do. Thanks Jesse.
Hank, that came out very nicely indeed.
It never ceases to amaze me that behind something that looks so clean and uncluttered lies a large amount of planning, agonising, preparation and effort. If your family fail to appreciate this, keep the chest and let them go. :)
John McGaw
Very attractive. And practical too!
Hank Knight
Thank you, Derek. You are dead right about the planning and agonizing - and the time it takes. It matters little whether the piece is plain or fancy, the time and effort are the same for the basic things.
Another example of "new" maple. This is finished with two coats of 1# cut shellac, the second with a little Trans Tint dye to help accent the grain, two coats of wipe-on gloss polyurethane and a final coat of wipe-on satin poly. It is much more amber than the photos show, and it will age more so.
Thanks, John.
Looks great Hank
Keith Newton
I was just wondering how the drawers are made.
I can't tell from the small photograph, but was wondering if you knew this little detail. Fiddleback and curly maple shows best when it is rift cut from the log. When it is used vertical, the figure shows better if one edge it up, rather than the other. Before choosing which side is up, you should set it up with the light coming from one side (top) like used in your photo. If the wrong edge is up, the figure doesn't show, but when you rotate it 180º, BOOM, it really shows.
The second drawer down on the left doesn't show well on my monitor. If you pull it out, then lay it upside down on top of the cabinet will show what suggesting.
It is hard to catch these things when they are laying flat on the bench. I'm not saying that you made this mistake, because i can't tell from here. I'm just wanted to share the information for any new woodworkers who read these forums hoping to learn.
Dave Nichols
great looking chest of drawers
Very Elegant, Hank
Your kids will carry the design with them, and it'll be a tough act for other makers to follow.
Re: Looks great Hank
Hank Knight
Keith, yes I know about the directional nature of fiddleback maple. I tried many different combinations of both grain direction and swapping out boards and found it impossible to get a "perfect" presentation. Some of the problem you see is attributable to the photograph, but not all of it. The left banc of drawers has more figure than shows up in the photo. If you take a couple of steps to the left when viewing the chest in the location in the photo, the figure in the left drawer fronts appears and the right ones fade. The bread board ends were a problem. I never got them where I was totally satisfied. I probably won't do a piece this large with figured maple again. I enjoy working with maple, but getting the figure to show the way you want it is maddening! It's a real problem with book matched panels. Thanks for pointing this out.
Thanks, Dave!
Re: Very Elegant, Hank
Hank Knight
Thanks, Mark. I'm trying to lead my kids gently away from Ikea. :)
Re: BTW
Hank Knight
The sides are solid maple. The individual slats have stub tenons and float in grooves in the styles. The top, center and bottom slats have 1" tenons that are glued and pegged to keep everything honest. The edges of the slats are beaded to camoflage any gaps that might otherwise show. Unfortunately, this detail won't show in the chest's intended placelent, but it will be nice if my kids ever move.
[URL=http://s50.photobucket.com/user/hankknight/media/Chest%20of%20Drawers/image_zps19zsywrq.jpeg.html][/URL]
A Noble Effort
I hope their future "economics" enable them to reject the lure of the Palazzo della Scheda a Scaglie.
Ooo, Design Flaw Exposed
Hank, you needed to triple the thickness of the center partition so they could chain saw the piece in half when they leave home. Expect a knock-down/drag-out over which one gets the chest!
:D :D
Gently?
I'd say this is more like a forced march from Ikea. Good work! :)
This is a lovely and, as you and others pointed out, deceptively complicated bit of work, and the result is worth the effort. FWIW, the Blumotion slides that we used in our kitchen renovation three years ago have worked flawlessly, despite some hard use. I don't know what those things are cycle-tested to, but I'll wager it's in the hundreds of thousands of open-close cycles.
Another aspect of this piece that bears talking about is the notion that it will live in an alcove, where the top and front are the only show faces. Considerations like this can be important when designing a piece.
I was going to steer this into a discussion of designing freestanding vs built-in pieces, but that's better left to another thread.
Again, Hank, nice work. Thanks for posting.
Re: Fortunately ...
Hank Knight
Fortunately, Mark, in this instance at least, my kid left home some years ago. The piece is for her and her husband and will go in their co-op in Washington D.C. If there's going to be any fighting, it will happen if they ever split, which seems very unlikely. :D
Jim Dillon
Hank, very nice functional design that should serve its purpose extremely well. I used Blum sliders (Blumotion sliders were not available then) in our kitchen redo 16 years ago and have never had one problem and still marvel at how smoothly they close. I also used Accuride sliders on some of the drawers and those have worked very well as well. Good quality sliders are expensive, but worth it. Thanks for posting. Jim
Re: Gently?
Hank Knight
Thanks for the comments, Ellis. I think my issues with the Blum slides come from the fact that this is my first time using them, and I'm fumbling around a little. I have all but one drawer adjusted to get the proper closure and reveal, but the bottom one on the left side is giving me fits! I'm going to work on it now.
Hank Knight
Thanks, Jim. As I mentioned to Ellis above, this is my first time using Blum slides. There's a learning curve that I'm still working through. I've used lots of Accuride slides over the years and have been happy with them. I think Blum's undermount slides give a more elegant appearance.
Learning curve
Keith Newton
There is a bit learning curve, but they are actually easier once you figure them out. Unlike the older stuff, most of it can be done without changing the mounting screws. Don't overlook the little levers at the back end for changing the tilt front to back.
Just do a google search for Blum Tandem Plus with Blumotion slides adjustments
