SDS Drill question, Dying?
I have a Bosch SDS drill and used it heavily the other day. It got hot. It leaked oil out the business end and over/through the chuck. Likely some seal has failed, Right? Any suggestions?
Re: SDS Drill question, Dying?
Maybe not a seal
Dick Coers
I don't know the exact workings of that drill, but they often use a heavy grease on the cams. You may have just overheated it and melted the grease. At the very least you'll need to get inside and apply the correct new coat of grease.
John in NM
I don't think it's dying. Mine did that years ago and it still works.
Re-greasing isn't a bad idea, but beware of fiddly mechanisms inside :D
Mine did that, still works fine. I think the rotary dial to switch between hammer/hammer drill/drill was also a port to add more oil but it's been decades and I can't remember.
John McGaw
Have to agree with the others -- it is probably OK. I have the Bosch 'Bulldog' (can't remember the number and I'm too lazy to go look) and it has occasionally shed a bit of oil/grease over 10+ years of use with no detectable downside.
Joseph Mulherin
Barry, go and buy the Rockwell hammer drill....cost about $136. It also is a regular drill for screws.
I used it a few minutes today and....
It seems fine. Wiped it down to keep the grease off my hands and stuff. Hope it holds up, it does not have a lot of time on it.
Jerry Nicholson
My Craftsman half inch drill has seeped a little grease ever since I got it - about 55 years ago. Still works fine!
Jerry
Jason Roehl in Lafayette, IN
Re-paint with grease and thin no more!
I have a 20-year-old Milwaukee hammer drill that did that to me about 10 years ago. I took apart the gearbox, cleaned it up and put in new grease. Good to go.
Jason
