Unique wood available
Clint Searl
Clint Searl
A friend has a pallet load of interesting pieces of ipe. I can arrange contact if there's interest in obtaining any. A description follows:
"These wood blocks were purchased in 1965 at the end of the 1964/65 New
York Worlds Fair in Flushing Meadows, Queens, NY. They were part of
the Brazilian exposition at that fair. They have always been stored in
a barn or garage, out of the elements. At the Fair, the blocks were
assembled into a free standing, small building in the Brazilian
Pavillion. The wood is Ipe, sometimes referred to as "Brazilian
Rosewood" or "Brazilian Walnut", and is practically
impervious to rot or insect damage.
Each block's four face edges on
both sides are chamfered, and the tops and bottoms are channeled and
raised so that every block interlocks with any other block, creating a
free standing construction with no other types of fasteners (no nails,
screws, bolts, etc.) . Each block is approximately 3 3/4" wide X 2
3/4" high and there are three lengths 5", 10" and 20", with
corresponding weights of approximately 1 1/4, 2 1/2 and 7 1/4 pounds.
Since the original building had a door opening and at least one
window opening some of the blocks have a 45 degree angle cut.
The wood on the pallet takes up approximately an area of 72" X 48" X 44"".
Re: Unique wood available
Sounds like it might make some turning stock. Does it want to sell only the whole pallet or pieces? Where is it in the country?
Dick Coers
Ipe can be very boring, but you can turn it down to 1/16" diameter for really fine finials. Great for wood crochet hooks as well. Polishes up great!
Clint Searl
Clint Searl
Located in upper Bucks County, PA. Pallet lot vs. piecemeal purchase may be negotiable. One piece would sure make a lot of ornament finials.
Yes, I'd like contact info. Thanks!
Clint Searl
Clint Searl
I've passed your email along.
