A55 Smoothing Plane
Need info
Need info
Need info
Doug Ridley
I bought a 2'' by 8'' walnut board that is pretty wet. Didn,t realize it 'til I started planing it. I will be making some small projects that require a bunch of pieces
approx. 8'' by 8''. My question -- If I go ahead and cut it into 8'' by8'' pieces and stack them about 6 pcs. high with some weight on them (thinking anvil) how long do you think it will take them to dry? Can also put a fan blowing on the stack.
Opinions or suggestions please.
Doug
Re: Need info
Re: Need info
John Veerkamp
Doug, you'll need to cut them at least two inches longer than you want the finished size. Walnut will check as it dries. Also you need to seal the end grain with wax, anchor seal of the like.
John
Re: Need info
Re: Need info
David Bair
I'd leave the board whole. It'll dry faster the thinner it is (2"vs6") and you'll be able to select the best portions (only the 2 ends will check) after the board dries.
Re: Need info
Re: Need info
The "old rule of thumb" is to air dry for 1 year per inch of thickness plus one year. So by that a 2" thick board would take three years.
I'm sure this is a gross generalization and if it holds true for one species, it probably doesn't for another.
What I do when air drying is use a pinless moisture meter and periodically make a reading. I think this meter will read about 3/4" deep in the wood. In much of the US a piece of wood outdoors will eventually reach 12-15% moisture. Inside, in air conditioning and heat, it will get dryer, maybe 9-10%.
Another thing people do is periodically weigh the board and chart the weight. When it is no longer changing it is about as dry as it is going to get. If kept warmer, it will dry faster. I too would leave the board uncut to prevent excess end checking on each smaller piece, and seal the ends immediately.
For study on this, one resource (my favorite) is R. Bruce Hoadley's book "Understanding Wood".
I am certainly no expert on this but I air dry a lot of wood for wood turning. The "rule of thumb" mentioned above falls apart with thicker wood and with some species. Most of the wood I turn has been drying for 4 years or more, some for over 10 years. I also stack and dry wet wood from the sawmill behind the barn. You just can't get in a big hurry when drying wood.
For boards, it is best to stack them with stickers between for free air movement and weight or clamp to encourage them to dry without warping badly. A single board can still be stickered above and below (well off the floor) and weighted or clamped. A weighted stack of small boards stacked tightly might dry in a decade or so but have a lot of cracks in the end grain! A fan blowing directly on the wood is generally discouraged since it may dry the surface too quickly and cause surface cracks and internal stress.
If you plan on resawing the board or planing it thinner, doing that now would help it dry quicker BUT at the risk of losing useful wood from shrinkage and warping. Thinner boards stickered and weighted properly should survive OK if you leave enough wood for shrinkage and to plane away minor warping. I once cut a bunch of small 1/2" boards from a green walnut log and made a bundle with small stickers between and clamped it together and it dried ok. With clamps you do have to periodically tighten the clamps or they will loosen as the wood shrinks.
An issue is how the wood will be used. Pieces cut for some uses might need a different level of drying than pieces cut for joinery.
Another quicker possibility is to acquire a kiln- or air-dried board to use now and save the wet one for later!
Re: Need info
Re: Need info
don stephan
Very thorough response JKJ. Hope you enjoyed Cincinnati and had some Skyline chili.
Re: Need info
Re: Need info
Doug Ridley
Thanks to all.
Re: Need info
Re: Need info
William Duffield
…but doesn't always have disastrous consequences. I have a stickered stack (4/4 to 10/4 thick and over 12" wide) of Liriodendron in my loft that had a fan or two blowing on it for the first year after it was sawn from a soaking wet four foot diameter log, and it's all straight and flat.
Re: Need info
Re: Need info
I agree. Most resources I've read suggest to air dry the wood down from sopping wet to about 20-25% before using a fan. Some suggest standing boards vertically during the initial drying - I've seen free water drip out the end of the board and puddle on the floor. Stain from fungus at the stickers can also be reduced by standing vertically. Sticker stain may not be as much an issue with walnut as it is with light colored woods such as maple, holly.
Gentle air circulation with a fan in a enclosed room should be fine, especially if running a dehumidifier in the room at the same time. When I'm drying batches of freshly cut turning blanks in my shop I can't believe how much water the dehumidifier pulls out of the air every day. One author said to gently circulate air in the room but not by forcing air directly through the stack.
Maybe the suggestion to avoid fans is since there is always going to be the guy who says hey, if gentle air circulation is good, then MORE should be MORE GOOD so get out the big fans, crank up the heat.
