First off ''Thanks'' for your insightful site. I would like to make my grandsons each a set of ''faux'' lincoln logs, making them longer so that more and different patterns of buildings can be made. I would like to make the base logs 24'' and graduate down. My question is would the next sizes be 16'', 12'', 8'' and lastly 4''? It seems right but not sure.
Obviously you can tell I have never done this before and I don't want to waste wood.
I tried to reach Ernie who had posted info about "lincoln logs". Using his 2 different email addresses to no avail.
I would very much appreciate any help you can give me. Thank You
Multiples of 2 in the smaller sizes and of 4 in the longer ones will give lots of flexibility. Be sure to make lots of 1 1/2 ones to lock wall and window edges. Typical sets have almost as many of these locking pieces as structural pieces. Sounds like fun.
You will be busy if you want to build a big set. No breakdown of individual pieces but their biggest current set is over 300 pieces. Retail prices from $70 to $300+ for the same model number set. Interesting project to turn these out with accurate routed "locks" by the dozens at a time. Show us your set up when done.
It's been a while since I've built with Lincoln Logs, but just wondering: should the incremental sizes be the distances between the milled flats where the logs interconnect instead of the overall lengths of the logs? Also, I remember having a number of very short logs with just one flat between them, used for supporting the ends of other logs at the edges of open doorways, windows, and ends of walls.
Hey, I just googled "lincoln log plans" and found this which may be of interest Didn't read it but I looked at the pictures:
I haven't made any, and haven't played with them in 60 years, but it seems it would be more efficient to cut the notches before ripping the individual logs apart. And then, with that many notches to make, I think I would take the time to set up a dado stack to cut them on the table saw, instead of at the router table.
Aesthetically, Lincoln Logs always bothered me a bit, because the ends were cut off square. A real log would be pointed and faceted on the ends, having been chopped down and cut to length with an axe.
Some very old cabins I saw looked like the ends were cut with a crosscut saw. I assumed the trees were chopped down with an axe then cut to length with a saw. I have a couple of old hand-hewn beams from such a cabin that have roughly cut square ends too.
I made "hand hewn" logs for this cabin. (I started with square then roughly rounded the corners with a spindle sander.) Stacked little stones with mud morter for the chimney and fireplace too. Good clean fun. :-)
OK, you guys have convinced me. I also checked out a couple of old log buildings I had taken photos of, and in spite of severe weathering they tend to support your methodology.
Not to fell the tree! For several years as a teen back in the early 50's, my cousin and I cut all the firewood and fenceposts for my aunt. She lived in a log cabin built by her and my Uncle back in the 1920's and heated with wood supplemented with a small amount of coal.
Her woods was 99% oak, in the area of Northern Indiana it was referred to as pin oak. The trees grew quite close together and were about 8" in diameter and well over 50 year old. They were hard enough and had sand imbedded in the wood so that the ax would occasionally spark when cutting. We did cut to length using a 2 man crosscut but unless you cut the stump about 4 foot high sure wouldn't have used a crosscut for felling!
I really doubt you could find many teenagers today that would work that hard!
Every vintage picture I have ever seen of a professional timber feller, shows the notch cut being done with the axe, and the felling cut done with a saw. You don't want a v cut on both sides of a tree that you need to drop in a specific place. Not saying you can't do it, just saying there are dead beavers laying around the pond because the tree fell on them! Also, a guy that knows how to use a two man saw also has a file in his pocket.
Well, your right about the pro's using a saw. BUT they did leave fairly tall stumps while my cousin and I cut most of the trees down leaving less than a foot tall stump. I sure wouldn't want to pull a saw back and forth sideways a foot above the ground! As I recall we never had any problem felling the trees where we wanted, in fact they usually fell within a few foot of where we planned. The pin oaks we cut were fairly tall - near 50 foot - and we limbed the trees with our axes, so wanted them laying in the clear where possible.
We did sharpen our axes pretty often and the crosscuts were sharpened prior to our day of labor. Don't recall sharpening the saws during the day but of course they were only used to cut lengths.
I do remember splitting the logs, man some were real bears, I recall a few times when we had several wedges and a splitting mall or two stuck in a 26" or so long X 8" dia. log.
When I was raising my family, I heated my large 1800's home with wood for 7 or 8 years. Of course I had chain saws and a borrowed log splitter then and felt like it was Christmas.
