I have a right tilt table saw. Many years old and no riving knife. For years I’ve done my best to avoid and find alternatives to making a French cleat over a length of over 12 inches. I need one now in one piece that is 28” long. I get really concerned. Over more than a few years I have experienced only two kickbacks with a table saw. One missed me but flew across the room and dented plaster some 20 feet away. The other actually hit me so hard I was worried about internal trauma. I’ve now placed me in a situation where I need to make another French cleat. I hate the prospect. With the board I have now the blade tilt will be within one inch of the fence at the closest point. Is there any method that makes it safer? Because of protrusions it is not possible to move the existing fence to the other side of the blade. Blade height? Fence modification? Feed rate? A much wider board? Note. I’ve never had a problem making a French cleat before on this saw, but I worry none the less. Are there tips I don't know about? How do I minimize danger?
Start with a wider board, and work on the left side of the board, rather than the side toward the fence. You can then go back and cut it down after the beveled ripping is done.
Your concerns are not unusual. By its very nature, ripping on a tablesaw between a tilted blade and a fence is an exercise in avoiding binding. So, to answer your question about optimizing the operation, there are a few things you can do to assure that your saw itself is not adding to the risk.
One thing is to make sure your fence is parallel to the blade, and I won't go into instructions here. Another, less-well-known tip is to "supertune" your tablesaw. This is a tricky concept to understand, but we covered it pretty well in a magazine article back in '95. (See link below.)
Technique is the other variable that needs attention. You say you have an inch between the tips of the blade and the fence for this particular rip. That is plenty of safety margin for a proper push stick. I'm a big advocate of those push sticks whose profile resembles a hobnail boot. I keep several handy in different thicknesses and lengths. The operating principle is to keep pressure downward on the workpiece with the toe of the boot while pushing it through with the heel. This way there's very little danger of the front end rising up and catching the blade. This type of push stick also allows you to apply a twisting force to help keep the piece tight against the fence.
And, to answer your other question, you can definitely set up your rip fence to the left of the blade and cut on the right. This way, the off-fall is not bound between the blade and fence. I still recommend the hold-down push stick, and be prepared for this operation to feel awkward if you haven't cut on the right of the fence before.
Blade overheating is another peril, especially if you're using a thin-kerf blade. Bevel cuts can produce a lot of friction, and this can heat up the saw plate and cause it to warp. This is a dangerous situation and should be avoided, so be sure your blades are sharp and you feed the work at a fast enough rate to avoid unnecessary friction build-up. This is hard to quantify, so I'm just trying to encourage your awareness.
I lost some sleep last night over this self imposed dilemma thinking only of table saw. Solved the problem using completely different tool. Thought about the jointer but the fence locking mechanism on mine is finicky. Decided not to fuss with it later by taking it out of square for this.
I'm literally using the router table to check old articles on French cleats when the answer was under my nose. Duh! Epiphany. I cleared all the stuff off of it, inserted a large 45 degree chamfer bit and did the cut in stages. Quick and clean.
After, I feel a bit silly for posting here with a single mindset. Alternative tool never occurred to me.
Thanks for the reading matter. And Brian, the block plane quickly relieved the small edge where the router bit was a bit shy in height. Mark, I have maybe four feet of the sink cleat. Didn't think of that either. Found mine loose in a yard sale and bought the two sections for the purpose of using it as a cleat. But until now never knew what it was really for and didn't know what it was called. Good to know.
Now that you are finished, here is another thought. You don't really have to tilt the blade to a forty five. Substantially less will work and make this a much less scary prospect. and you can put a screw or two through the back of the cabinet into the lower cleat to make sure the cabinet does not fall off.
I would bevel cut the board about 1-2" in from the far edge, with a wide side of the board facing in to the fence. You can push this along the fence without danger of kickback. Then simple straighten the blade and cut off the mating piece for the french cleat. There is no need to trap a section against the fence.
for many years I subscribed to just about every woodworking magazine out there. There were many articles on aligning the table saw. I always had the problem of the blade burning when tilted. When I read the article included in that link many years ago it was an AHA moment. To this day I think that is still the only article that mentions that. It is a serious pain to do that adjustment on a contractors saw but now that I have a cabinet saw the first thing I did was go through that adjustment while I was truing up the blade. Makes a fantastic difference.
Well prepared flat stock is also helpful. If you are ripping a wide board to make two pieces, you don't have to rip all the way through. Leave a really thin section to hold them together, run a knife down the kerf to split the two, then clean up with a hand plane or sandpaper.
"Because of protrusions it is not possible to move the existing fence to the other side of the blade."
Right tilt saws have never bothered me at all due to the practice of moving the fence over to the left when doing bevel cuts. What is it that is keeping you from doing so and why are they worth keeping?
Its easiest with a fence like a Biesemeyer, but I've done it with a unifence and also the jetlock on my ancient saw.
I actually prefer a right tilt saw for bevel cuts, since I can stand to the left and more easily control the piece (like when cutting raised panels) as it passes the blade. The longer fence rails on the right side prevent this on left tilt saws and you have to stand in the normal place and lean over - harder for me to control a panel on edge that way, even with the jig I typically use. Can be done of course.
If you have a track saw, they do this very safely and you get a nice smooth cut the entire length of your track. Still a good idea to do your cut on a wider board and rip the cleat off at 90 degrees later.
But there are disadvantages to using any angle other than 45°. If you cut them all at the same angle (and even better, if all from the same thickness of stock), then later it is a simple matter to rearrange any shelf or rack onto any cleat. If the two halves of the cleat are at different angles, one half of the cleat tries to pry the other half off of whatever it is attached to.
Over the years I've amended the fence that came with the old Jet JTS 10 contractor style. It is the aluminum original fence that came with the machine but with new face that I have shimmed and trued, I don't think I've used the fence on the other side since I made the "improvements". Anyway, the protrusions are knobs that pull or loosen bolts allowing me to adjust the fence straight its full length. A newer, better aftermarket fence should have been purchased long ago but now that saw is so old I'm sticking with the girl I brought to the dance.
Bruce writes ( Don't know about his saw, but on my old contractor saw the start capacitor on the motor stuck up above the table top when tilted to a 45. ) Isn't there a stop set screw in the top surface of the saw to adjust for blade height ? V-belt length may also need to be considered if your not using the stock V-belt. Or the way the motor is mounted to the plate. I have a Delta Contractor's table saw, and a Delta removable outfeed table that was made particularly for the saw. I had to do some adjusting to get it so the motor capacitor cover would not hit under the outfeed table, which meant that the motor could not be any higher then atleast 7/8" under the table saw's top surface. It wasn't that hard to do.
Thinking about it a little more, the blade height stop is more of a adjustment to keep the arbor pulley away from the underside of the cast iron top. If the capacitor cover is above the top surface, then more then likely it's because the motor is mounted to low on the motor mount, and or the V-belt is not the right length.
You can use a feather board mounted on the fence to keep the piece against the table and stop it from coming at you. It's a little klutzy to get the last bit past the saw blade.
An alternate is the band saw with the table tilted.
Lastly, don't try to cut bevels on wood that is prone to warping - like black locust - and only work with properly prepared flat and squared stock.
.......and stand well to the left of the blade, out of the line of fire.
Good thought. I am so happy in my shop to get anything hung up it never occurs to me to rearrange it. OTOH, if you started with a lesser angle and were consistent, it would work well.
Are you logged in? Since you can post either way, logged in or not, it can get a little confusing when you want to post pics - need a profile and to be logged in for that.
