Decimal Inch and Metric and Fractional Caliper *LINK*
John McGaw
Don't know if this is of any interest or even appropriate here (I'm sure it will disappear if it is not appropriate) but I just got a cut-price offer for a really neat little digital caliper which might be of interest to woodworkers in that it displays in fractions as well as more conventional units. I have no financial interest in the company involved beyond having sent them money in the past.
Aside from the general utility that a caliper offers for all sorts of measurements in the shop, it's also a heck of a lot easier to read 1/64" on the LCD display on a digital caliper than it is to see the 1/64" marks on a tape or rule. (At least for my tired old eye's)
Bob in NJ
Re: Decimal Inch and Metric and Fractional Caliper *LINK*
I have one. I find it useful. The depth gauge on my planer also reads out in 64ths. Sometimes I want more precision than 1/64th inch. Also, sometimes its useful for converting from inches to metric and back. Motise and tenons' thickness needs a lot more accuracy than 1/64, but I can't see that much detail any more.
The problem with these that might be Chinese made, is that you don't know who made the particular caliper you are looking at. Some of them have the annoying feature that they look like they've turned off, but they keep draining the battery. If you want to use them the next time you need them, you have to remove the battery every time you put them away.
but they are weak in the display component. I bought a couple of these off of ebay at a reduced price of $18 thinking that they were cheap enough to use as beaters. I'm disappointed. The manual on/off is a royal pain. The battery goes quickly if you forget to turn it off, or you mistakenly turn it on by depressing the button putting it away. The worst problem however is that the plastic display cover straddles the bar in two halves and mine have dumped the display when replacing the battery. When that happens the digital window goes blank -- only one came back. These are beaters and I have one that still works, but they are not a good investment -- electronically
I got swept away by it being metal, the digital dual scales and price, but the old gray plastic dial Swiss made General caliper (with green in dial} cost the same and they have lasted a decade or more. By the way even without the digital display you can still lock it on a size under 6" and use like a story stick to accurately measure distance without using any scale. But what most people buy these for is the digital display and for me it hasn't lasted more than six weeks in use. .
The "zero" button is especially useful when planing stock to thickness, if you have a sample at hand at the target thickness. With two measurements (it does all the math for you) and if you've calibrated the height crank on your planer, you know just how far to crank it to get the final pass right on.
On the planer casting, right next to the bed height adjustment crank handle, I have three numbers written: The distance the bed moves with a 360° rotation of the crank, in 64ths, .01" and mm.
Another very useful number to know and make sure you remember, if you are drilling holes in the ends of turning stock (for pepper mills, tool handles, duck calls, etc.), is the number of threads per inch on your lathe's tailstock feed. I wrote it down on the tailstocks of both my lathes. For smaller lathes, it's usually 18 tpi and for larger lathes, it's usually 16 tpi.
I also have one of those and really like it. I like buying from the Little Machine Shop. They have always treated me fairly and have immediately fixed any issues. You can call them and speak to a knowledgeable person too!
For the wood shop I find myself using these analog calipers as much or more than the digital (found on Amazon):
It has numbers to 16ths and tic marks to 64ths plus an inner dial marked in hundredths. No metric. This caliper is always on and the battery never runs down. :-)
BTW, for my woodturning it's rare I need anything other than relative measurements so I keep a small drawer full of these:
I have both digital and analog fractional calipers. I love them for woodworking. I use the analog ones almost exclusively. In fact the batteries in my digital set died a long time ago (one reason I like the analog ones) and I've never bothered to replace them. The main reason I like the analog caliper is that I can tell with a glance at the dial whether 1 27/64 is greater or smaller than 1 7/16 without doing any math in my head.
Where do you get the inexpensive ones you use for turning?
Unless they are a lot less expensive than I imagine they would be, the nail full of spring outside spring calipers I use would be more economical in the quantities needed for spindle duplications. Old spring calipers from Starrett, Lufkin, B&S, etc., can usually be found at old tool sales (tailgating) for quite a bit less than $10 each.
I notice you've modified the upper caliper in your picture, to keep it from catching on the turnings. I have to do something similar to take the sharp points off of my spring calipers.
I see from the "camel" site they were at about $4 for years, dropped to below $3, shot to over $7, then dropped but then charged for shipping keeping the price at over $7. (I think it is common for Amazon vendors to use this scheme to raise prices then make it look like they are lowering them when they don't sell well at the higher price.)
I have found the same thing in the tool section of Home Depot for about $8.
At $4 each they were cheap enough to give some away to new turners. Once I ordered a half dozen and they sent spring calipers by mistake, refunded the cost, then said to keep the wrong ones. So I have some of those to give away too!
I do have a number of good spring calipers, Starrett, General, Craftsman, etc. in various sizes and types: inside, outside, divider. I love the Starretts - very nicely made and the larger ones have the quick adjust feature.
I actually prefer the cheap verniers for several reasons:
- The jaws are quite thin and fit easily in the slot made my favorite parting tool I always use for sizing.
- When sizing to an existing diameter, I find it very quick to close the caliper on the diameter then tilt it a little to open up the jaws a bit so I can sneak up on the exact diameter while turning.
- As you noticed, you can make a large radius on the jaws to keep from catching. (You can also file a step to make a go/no-go caliper.
- I can get inside diameters with the same instrument and the points can be used to scribe a rough diameter easily on the work.
- And they will measure depth!
I use the word "measure" loosely - I have never used one of these for other than transferring dimensions. I don't even know if the scales are accurate. I used one early this morning to get a dimension on an arbitrary drill bit then to size a little tenon on an acrylic ornament globe. I have no idea what size drill bit I grabbed.
Since they are made from stamped metal sheet I go over the jaws with a file or sand paper to knock off any rough edges then hit the jaws with a metal polishing wheel. (Those in the photo are not yet polished.) I fastened a magnet on a ledge behind the lathe and always keep one within reach. When duplicating something with more than one diameter I grab a few more out of the drawer. :-)
Jim Dillon
John, I have both an analog and digital calipers. The analog version I use ALL the time especially when milling wood. The model is similar to what John Jordan posted. I got the digital when I purchased a Festool Domino as everything is metric and the digital makes it so much easier. Mine has an automatic shutoff which is important. Nonetheless, like a flashlight, it seems like every time I need to use it, the batteries are dead :-(. Jim
William Duffield
Yup! Mine stays in my Domino Systainer. As I noted in another post on this thread, after finding it dead a few times, I finally learned it is essential to remove the battery when I'm done using it. Using it is still easier than leaving a pile of assorted size tenons laying out with fractional dimensions written on them.
