Heavy duty mobile base hardware?
I am looking for a means to occasionally move a milling machine. The total weight will be over 800 lbs.
I'm welding up a heavy steel base. If I can find them I would like to attach some kind of caster that can be retracted so the base (and levelers) will sit firmly on the concrete floor when not being moved. Most of the mobile base hardware I've looked at is not rated for enough weight or does not even list the weight limit.
I'm willing to use a pry bar or build some type of a jack if needed but I'd rather have casters permanently attached rather than have to slide something underneath. It would be best not to have to tilt the machine much.
Any ideas or places to look? Some industrial solution?
