Need to cut a weird angle on table saw
Ron Peterson
Hello, I am making a table that has an angle coming down from the top that I need to make a table leg going down at 90 degrees. I have calculated the angle that I need to cut on the leg piece and it is 40.7 degrees. My Unisaw will only go down to 45 degrees. I am thinking that it I put my saw at 45 degrees and lift the board through on a cross cut sled at 4.3 degrees that I can achieve this angle. Is my thinking correct?
Best regards,
Ron
Re: Need to cut a weird angle on table saw
Kneale Brownson
Kneale Brownson
I'd fasten something to the board to ride on the table to achieve the desired angle.
Need a Visual
Ron,
Can you do a drawing of the part showing the angle you need to cut? I'm just not "seeing" what you need to do from the word description.
Re: Need a Visual
I agree with Mark. If your saw will cut a 45* angle why won't it cut anything less? You don't have a stop or index for the lesser angle, but you can set the blade and lock it. Thus, I assume I am not understanding the question.
Re: Need a Visual
I wondered the same thing. I assumed it was a matter of how the angle was measured (the way a 30-deg angle is also a 60-deg angle depending on the reference plane.) If so, perhaps clamp the leg stock to a vertical jig or better, to an angled wedge and leave the saw blade vertical.
AZ in Colorado Springs
Build a tall fence that rides on top of your table saw fence and clamp the work piece vertically to it. Set the blade for 4.3° bevel. Voila!
what I'd do
Tom Sontag - St. Louis
I would draw the cut on all four sides of the leg piece, cut close to the line with a handsaw, and then clean up the cut with my low angle block plane.
I do not trust my machinery to get fractions of a degree accuracy and it does not sound like you are making dozens, so skip the elaborate jig approach and just have at it.
agree
Agree except I would cut the rough angle on the band saw because I have one.
