Logging with a trailer
I asked here how to load a log and received experienced advice which I put to use loading two logs from a tree that blew down. The logs were too nice to cut for firewood.
PIC1
I cut some 3' sections of increasing diameter from a downed hemlock and tapered the ends. The log was rolled onto these ever larger pieces to act as a fulcrum.
Pic 2
The goal is to get one end above the trailer bed. At this point the trailer is backed under the raised end.
PIC 3
A winch of some sort is hooked to the end of the log and it is pulled aboard.
PIC4
If a log sticks out the back of the trailer it can be shoved to the front by backing the end of the log into a tree.
Re: Logging with a trailer
don stephan
Great use of pictures to make the explanation easy to follow, and the procedure looked to be relatively safe. Still, always nice to have a 2nd person, in case the unexpected happens, to call 911. Perhaps you had a shy 2nd person.
Dang, And you made that look so easy,
Keith Newton
Wish I could do that. ;>)
Cherry?  **
Glad it worked out for you
Grant Smith
Bill,
Glad I could provide some advice, and glad it worked out so well. The bucket seems to have been able to help reduce the number of steps, however precarious it looks. You provided a small number of photos which clarified the process in an economy of moves.
I expect you are well aware, but make sure you clean those logs before heading to the mill.
Might be worthy of an article.
Regards,
Grant in Iowa
bucket
It was a temporary substitute for me sitting on the end of the log to keep it tipped up while I took the picture. It wasn't holding much. It is the chain bucket and half full of logging chains I can just lift it!
Just finished pressure washing the logs and off to the mill which does not have a debarker.
Hope you have plenty of tongue weight,
Keith Newton
It is hard to tell from the photos how much is sticking out, but having this much weight can be very hazardous if the load is too balanced. Bumps in the road, especially in a curve will start it rocking where the tail is wagging the dog, which causes the dreaded jack-knife situation.
If you feel it setting in, the brakes are not your friend, they will only make things worse.
philip f Duffy
I once rolled 3 very large logs up 2 long poles over the side of the trailer, with 2 ropes tied to the sides of the trailer and under the back of the logs by just backing up the pickup truck as the power source. Easy as pezzy. Philip
not my first rodeo with a trailer
I haul firewood, gravel and other stuff up to 1.5 ton on this trailer regularly. I always take a shovel to the quarry for when I can't convince the loader operator to put it far enough forward.
Excellent case of nearly lost trade of rigging.
Chuck Nickerson
Moving large objects with muscle and leverage used to be common.
At http://www.theforgottentechnology.com/ Wally Wallington shows how Stonehenge could have been built using perhaps a dozen people.
We have forgotten so much.
Book suggestion *LINK*
Tom Dunlap
I don't know why I didn''t think of this originally.
There is a really great book, Moving Heavy Things, that has wonderful illustrations about tasks like this.
I see that it can be bought for $0.59!!!!
The first place i read it was a the library. Then a friend gave me a copy for a gift
Moving Heavy Things
Book suggestion - Thanks!
Tom,
Thanks for the suggestion on the "Moving Heavy Things" book. I ordered one and it came today. You are right - the illustrations are great. A quick look through it and I learned some new techniques and the names of some of my old techniques, for example, "parbuckling".
Excellent little book.
JKJ, confirmed book junkie
