What Reeally is an "In The Wood Finish"
don stephan
This is a sincere question, not intended to cause battle lines but . . .
Often I've seen the term "in the wood finish" but never a definition. This morning I came across "Think Finish First" by Jeff Jewitt in Fine Woodworking #141 (March/April 2000) pages 58-63 which inspired finally posting this thread.
From the article "Both linseed and tung oils are penetrating finishes, which means they penetrate the fibers of the wood and harden. . . . These oils are usually not built up with enough coats to form a surface film, like that of varnish or lacquer, because the film is too soft."
When linseed oil was more popular as a finish, application instructions often included something like "once a day for a week, once a week for a month, once a month for a year, once a enough year for life." Some people may never have applied enough coats to do so, but with enough applications linseed oil and tung oil can build to make a cured film on top of the wood. The first coat still penetrated into the wood, but when it builds to include a cured film on top of the wood, is it no longer an "in the wood finish?"
I don't have experience with poly finishes, but I have used P&L 38 alkyd varnish often the last few years, both as an oil-varnish blend mixed with mineral spirits and boiled linseed oil, and as a wiping varnish thinned 50-50 with mineral spirits. Applied as a wiping varnish, the varnish "warms" or darkens the wood almost as much as straight boiled linseed oil, and I can't feel a tactile difference on the wood between one coat of each after a couple days, maybe after two or three coats of each. Certainly, after 4 or 5 coats of this wiping varnish mix, I can feel a building film, but the pores of oak and ash certainly are not fully filled, perhaps not even the pores of a finer wood like Bradford pear.
Later in the article "Oil and oil-based varnish, solvent-based lacquer and shellac all deepen the color of the wood and increase surface luster the most. The finishes wet the cells of the wood, penetrating into the surface. Other film finishes - notably water-based finishes and some catalyzed lacquers - tend to lie on the surface. By not penetrating it as much, they make the wood appear lighter in color."
Some comments I've seen and heard over the years seem to suggest that only [boiled] linseed oil, tung oil, and commercial products such as Tung Oil Finish and Danish Oil can produce an "in the wood" finish. But if, as said in the article by a well respected finish authority, oil, oil-based varnish, and shellac all penetrate the wood, then is an "in the wood" finish dependent not only on the finish itself but also the final thickness of the finish?
Why is this worth a thread? Becoming a better woodworker is a life-long education and skill development pursuit, and it would be nice to think readers of this and other forums pay attention to and learn from what is posted. It would also be nice to think becoming a better woodworker depends on learning to evaluate information and apply learning rather than simply memorize summary statements that may or may not present a complete picture. If there is more to determining whether a finish is "in the wood" should additional explanation be included so that a novice reading a post really understands the meaning of "in the wood?"
I'm starting this thread because I do not have a clear understanding of what makes an "in the wood finish" and would like to continue learning and becoming a better woodworker.
Re: What Reeally is an "In The Wood Finish"
Something doesn't make sense
I agree with every observation you reported.
A couple of facts:
Below the level of a few cells the finish is not going to have any observable effect on appearance.
Penetration of finish will depend on viscosity and wetting of the wood. In 10 minutes I do not see any reason why any solvent based finish would penetrate to a different depth and in all cases this depth will be deep enough to do what it is going to do for appearance.
The appearance of a finish depends almost if not entirely on its thickness, refractive index and any dulling agent present. So for example, I can spray a thinned, dulled Kemvar conversion varnish and when dry it looks like an oiled finish.
Conclusion: the term "in the wood" has no practical meaning. Any finish is likely in the wood sufficient to establish what ever appearance it is going to. Something like oil that takes days to weeks to cure may penetrate deeper, but so what. It just makes this finish harder to build a surface coating. I don't see an advantage.
not so sure I agree with this.
Keith Newton
"Conclusion: the term "in the wood" has no practical meaning. Any finish is likely in the wood sufficient to establish what ever appearance it is going to".
I had a finisher about 20 years ago who thought the best way to make a lot of money was to use the least amount of material as possible. I had built a 40' long fresh for the controll center for an airline company flying packages for UPS before they did their own planes. The desk was all Genuine Mahogany, and his idea for sealing it was to spray lacquer from about 2' away with a fine mist coat which was dry by the time it hit the wood. The wood looked as dead as if it were raw. There was no luster whatsoever. It just made me sick to see how that killed such great wood.
I'll admit I like a in the wood finish where it is appropriate, and feel that getting the surface cells saturated is important if you want to maximize chatoyance.
As for whether there is any benefit gained from wetting out deeper, I think a pretty good argument could be made for reducing moisture penetration, especially for objects used in a kitchen.
One product I've started using is Smiths penetrating epoxy. I'm using it on my turnings, and some bar and table tops where cold drinks can leave a circle.
Another benefit with this product, is that when it sets up in the cell walls, it makes a soft wood tougher. I used it on the work top for a kitchen island that I built for our cabin 2-3 years ago. The wood was Eastern Redcedar, which is too soft for heavy use, but after one coat of CEPS and one coat of Minwax wipe on poly, it looked like many more coats, plus made the surface as hard as Formica.
There was another unexpected benefit. The two book matched 16" 10/4" thick boards has great color with gold, pink, purple and reds. The work top is still holding its color, while all the legs and drawer fronts that only got poly have changed to a light brown/ tobacco color.
It is expensive, but not so much, if it eliminates 2-4 coats of other products, when you factor in the time.
Re: not so sure I agree with this.
John in NM
I'm not sure that your guy's rather oddly extreme finishing schedule negates what Bill is saying though.
I believe he means that there is no practical difference in penetration between something like BLO and polyurethane. The difference is in film above the wood more than anything else.
Samples I have finished and sawn in half tend to back this up. I have seen a few pieces that were finished through drum soaking of very much thinned oil - those are the only examples of really deep finish penetration I've ever seen (setting burls aside, being all endgrain and rather punky).
lacquer i sspecial
Lacquer is formulated for the viscosity of the finish to build rapidly as the high volatility solvent evaporates. The viscosity of cellulose based polymers (for example nitro cellulose) increases with the 3rd or 4th power of concentration. I would expect that lacquer would not penetrate any significant amount into wood. On the other hand I believe the difference in appearance of an oil finish vs varnish is the thickness of the coating above the wood.
I agree that deeper penetration would lead to less water penetration, and slower response to humidity changes.
Re: Something doesn't make sense
I agree with Bill with one exception. I used to do a lot of hunting, and my firearms always ended up with a BLO finish. The major advantages to this finish were that it would prevent water from penetrating while I was hunting, and as the finish did not build a thick surface film, it was easy to remove scratches and re-apply the BLO. After every hunt I would rub on the BLO with my bare hands, then allow to sit for a while before wiping off any excess. Worked for me for many years. The few firearms I have seen with hard, thick finishes that were actually used in the field always showed the scratches and scrapes they received.
Back in the early 1950's my BIL taught me how to refinish some of the scratched up stocks with the thick film finish. We would break up a glass jar and use the shards as scrapers, after removal of the old finish we sanded the stocks and applied several coats of BLO.
Agree on all points
Nothing beats a zillion applications of oil to a stock of a rifle or shotgun used for hunting (as opposed to collecting). All my user stocks are stripped and oiled. But its not a finish I want on my sock drawer.
