Twisted Board
Twisted Board
Twisted Board
Stuart Johnson
What is the best way to get twist out of a board. I think I have the right term, it is a board that when placed on a flat surface two opposing corners will touch and the other two won't. Running it through the jointer and planner seems like it would take off so much that by the time there wouldn't be a lot left.
I have the normal power and hand tools.
Re: Twisted Board
Re: Twisted Board
David Yoho
While there are probably other ways to deal with this problem I have done it a few ways. First, if the board is thick enough to begin with, I just joint one face until it's flat and then run through the planer.
Depending on the width and what is needed from a board that's twisted, I have also ripped it in half, jointed, and planed, and put the pieces back together.
Depending on the length required from a twisted piece, sometimes cutting a longer piece into shorter lengths before dimensioning reduces how much must be removed.
Re: Twisted Board
Re: Twisted Board
John McGaw
Reducing the length absolutely will improve your chances of getting something useful in the end. If the original board is 8 feet long and has a uniformly-distributed twist of 10 degrees then cutting it into four equal lengths will reduce the twist that needs to be worked with is 2.5 degrees -- much more manageable. It sometimes turns out that twist is not uniform over the length and finding the best portion to use will sometimes get you where you closer where you want to go. There is no question that proper jointing procedures and then planing are the proper route and a lot of care is needed to make sure that the jointing passes are uniform and that the board doesn't rock during the process lest the problem remain or get worse..
Re: Twisted Board
Re: Twisted Board
John in NM
As the others mentioned, pre-cut the board as nearly as feasible to the sizes you need for what you're building - say a half inch to inch over in each direction.
Then flatten one side on the jointer and plane the other to match. You may still need a fairly thick board to get away with this, and you do need to keep the pieces long enough to run through the planer (say more than 12")
Other than this, I've never found a way of correcting twist, there is just no magic to untwist wood.
Re: Twisted Board
Twist is just cupping in a board with spiral grain
Keith Newton
Or the pith runs diagonally across the face.
While I agree with the suggestion to cut parts before planing, if he had ask how to get rid of cupping, someone would probably have suggested laying it cup side down on damp grass, with the crown side up to the Sun.
I don't normally agree with adding moisture to the concave side, without knowing what the MC is now and was before the cup or twist occurred. Most of the time, if the wood was KD, and flat before purchase, I would bet that it had gained moisture, so I like to think about applying heat to the convex side, while shielding the concave. You can still use the Sun as a heat source, but laying it on top of something to prevent air flow to the already concave underside, while letting the heat from the Sunlight dry the other seems to make more sense if the MC is above 6~8%, which should be the EMC if it goes to live in a heated and cooled environment.
However, if you know this board is air dried wood that has never seen a kiln, the MC is probably around 12% now, so while the above suggestion to dry the convex side on down may straighten it for now, but if you use it in a project where it is unrestrained, will probably mean it will return after the work is finished.
Re: Twisted Board
Re: Twisted Board
AZ in Colorado Springs
I have had some success minimizing loss of thickness by using both a push pad in left hand and push stick in right hand, and holding the board "level" for the first couple of passes over the jointer. Then the board rests solidly and continue with a few more passes until the bottom is flat and move to the planer.
Re: Twisted Board
Re: Twisted Board
Stuart Johnson
Thanks all for the information. I also found an online article that showed how to hand plane the high ends. I'm surprised I've never run into this before.
