Biesemeyer splitter
Biesemeyer splitter
Biesemeyer splitter
Johanna Johanson
My Bies splitter no longer lines up with the blade. It is slightly bent.
Here's the question - should I try to straighten it somehow or should I buy a new one? My straightening attempts have not been successful so far - probably because I am afraid I will damage it even more.
Re: Biesemeyer splitter
Hank Knight
If your option is to buy a new one, you might as well try to straighten it. You've got nothing to lose. I had an after market splitter on my unisaw that I used to straighten occasionally. Never seemed to hurt it.
jessecloud
There's a real safety issue here, if that splitter bends the wrong way, there could be a serious accident. I would either buy a new one (if they still make them) or take the old one to a machinist.
If the splitter seems flat, try putting a metal shim (I cut open a used beer can) in the holder to make the splitter right angled to the table.
In the mean time, I would imagine that cutting without a splitter is better than using a bent splitter.
Now that riving knives are mandatory on new saws, I suspect the aftermarket splitter industry is pretty minimal.
Be safe!
It ain't.....
Brian Roberts
rocket science!
Flat is flat.
William Duffield
I'm going to go a little further than Jesse. Cutting without a splinter and cutting with a bent splitter are both really bad ideas.
Compared to modern saw designs with a built-in riving knife, the Beisemeyer riving knife for the UniSaw is fussy and difficult to install and adjust, and there are lots of older saws that cannot be fitted to it. But, if it's your only riving knife choice (short of replacing your saw), do repair it, tune it up and use it.
Tony - Memphis
My old one did that and I just bent it back. I would push it and check it, push and check, rinse and repeat, until it lined up with the blade. Just take small steps and you should be able to coax it back into alignment. YOu could also do it in a vice and use the TS surface as a reference for flatness.
Tony
johanna
I like the idea of using the vise - I'll try straightening it - it is only very slightly bent, but that's enough to be a problem, of course.
johannaj
johannaj
Rats! No success yet on straightening the blade. I think I'll look for a machine shop to straighten it. Meanwhile, I have searched the internet diligently for a replacement - it's out of stock everywhere. I did find just the blade (no pawls, no mount, nothing but the blade) for $141.01! Yikes!
I'm torn between buying that blade and buying a Delta splitter for $79 (probably should buy two if I go that route - they look less sturdy than the Bies!).
I am also planning to call Delta tomorrow to see what they recommend for a 2002 left-tilt Unisaw. They evidently bought Biesemeyer, so what has happened to the Bies splitter?
This has been a bummer...
Tony - Memphis
Wow! Had no idea of the prices on those things. I'd suggest ebay, but you might end up with another bent one. Hopefully, a shop can "straighten you out" without much trouble...or money! Something to look out for too...there are tolerances that add up here...the mounting, the bracket, etc. So, even if the plate part is perfectly flat, it may not line up perfectly with your blade. So, make sure and check it after it gets flattened. To be honest, I haven't checked my PM splitter in a while, but I bet it is not "perfect" either. Not enough out to make a difference or I guess I would notice.
This reminds me...I used to be in the race car parts biz...you'd think something as critical as a camshaft would require some hi tech wiz bang technology to get it straight....nope....it was an old rickety wood lathe fixture with dial indicator hung off and a guy with an impact banging the heck out of it! Yep, very crude...but it worked. Interesting, I was surprised that they actually banged the low side, not the high side....backwards, huh!?!
Anyway, good luck . Sorry for the trouble. My first splitter was masonite!
