Fastening a top with traditional pocket screws
I learned this technique from Steve Hamilton. I will illustrate the steps while not attempting to flaunt the result. Steve’s handiness with a carving chisel greatly exceeds mine so his results look better. I will be attaching the top and base to the bed side chests of drawers using pocket screws. Illustrated is making a pocket in the base frame.
The problem is how to get the pocket located so the screw sticks out the right amount, and not through the top.
Easy as it turns out.
1. Drill an angled hole in the apron. PIC1
2. Align the screw to be used so that the desired amount sticks above the apron (the part that will embed in the top to hold it on) PIC 2
3. Mark the location of the screw head on the apron.
4. Drive a chisel into the apron at the location established in step 3. This operation locates the bottom of the pocket. PIC 3
5. Carve out the pocket up to the flat established by the chisel cut with a gouge. Pic 4
