A problem with finishing the recent walnut pieces
When scuff sanding the first coat of finish there are a lot of white finish particles generated. Picture 1
Picture 1 shows the test piece I always carry through a finishing project to avoid surprises.
Typically these white particles are blown off and it doesn’t matter if some are left in the pores. If the finish wicks into these white pores the white disappears as seen in the second picture.
However, one set of drawers was made from a board that was more porous than usual. The white stuff stuck tenaciously in the pores. When I came back with the second coat it bridged some pores and left white in these pores. It did not look good. The solution was to thin the finish even more to lower its viscosity. Thinning enabled the finish to wick into the pores of the drawer front and the white was gone. PIC 3
Had this fix failed I would have waxed with dark wax to fill the pores with dark pigment.
Re: A problem with finishing the recent walnut pieces
Clint Searl
Clint Searl
I don't know if successive coats of catalyzed solvent lacquers will burn in, but I find that one-part solvent CAB or NC lacquers don't need to be scuffed between coats. Increasing reduction will level and build as appropriate.
not scuffing for adhesion
The first coat sets up all sorts of prickles that need to be mowed off with sand paper to get a smooth second coat.
Clint Searl
Good point...
Clint Searl
I do hit the first coat with a maroon pad and blow down.
sanding with a pad
Maroon is too coarse for my finish. The scratches don't fill with the next coat.
I use gray.
The advantage is that the pad picks up most of the dust and it doesn't pack in the pores. However, the pads are not as effective at flatting a surface that has a lump here and there where finish has wicked up around a particle of junk. I use sand paper on high end work and pads for stuff like house trim.
Clint Searl
Re: sanding with a pad
Clint Searl
The maroon pad knocks down the nibs just fine. Its "coarseness" cuts off any pimples and is eliminated by subsequent coats. But different strokes for different folks.
don stephan
If you raised the grain with distilled water and knocked down with light sanding when dry, wonder if the first coat of finish would still have the wood frizzies.
A Good Shop Vac
with a brush would remove about all the dust. A blow gun and 100psi works well also.
Jim DeLaney, Austintown, Ohio
I like the Mirka pads. The 1500 'grit' stuff works great between coats.
Re: A Good Shop Vac
I agree with the shop vac and brush idea, but as a note of caution, be careful using the compressed air. Under some conditions they either spew moisture or they cause condensation on the surface. Its a good idea to have an air line dryer in the line and pay attention to the weather. Also, I some bitter experience with an air line that had an oiler in it for air tools. A little oil goes a long way in lacquer.
