Finishing Schedule for recent walnut pieces
The surfaces were sanded 120 through 180 with a quick touch up with 220. End grain sanding stopped at 180.
The stain was rubbed on like applying shellac with a rubber. It took less than 3 TBS to do the two pieces. The stain was formulated : 16 grams Japan Color Burnt Umber, 12 grams linseed oil and 100 grams General Finishes Prestain. First finish coat was 1 part xylene plus 2 parts Kemvar M conversion varnish. Cure overnight. Scuff sand with 400 stearated paper until smooth. Dust with 90 pis air. (at this point I had a problem described in the companion post.
Apply second coat of varnish typically diluted as before.
note: lighting changed. appears a bit red than reality
