A neighbor has a cement walk from the driveway to the front porch that runs beside the garage. The walk has "floated" away from the garage and there is a 3/4" to 7/8" gap between the garage foundation and the walkway. Some weeds are growing in the gap.
What is a durable material to fill the gap to keep out water and seeds? I'd drench the gap with roundup before sealing to kill any roots still growing down there.
I noticed that the maintenance folks here at work were filling all the concrete gaps with something and it seemed to work very well. I looked it up and bought some to fill the expansion joints/gaps in my driveway. The original filler was that fiber board or whatever that stuff is. Anyway, it has held up pretty well over several years now. Looks good and no issues. I added foam backer rod before I filled the gaps. I have had a couple of splits, but i think that was my fault.
The product is Novalink and I got it online at bestmaterials.com. Note that there are color options.
An easy fix would be to use one of the expanding foams, like Great Stuff. You could mask the wall, then trim the excess off with a butcher knife. It can then be sprayed with paint to match the color or brick or concrete.
On a smaller gap, I've used a Liquid Nails brand Concrete repair in a caulking tube, on my sister's washed gravel suspended slab. I sprinkled some sand and pea-gravel on it, which really blended perfectly. By itself, this sounds like too large a gap to be suitable, but it might be a good topping to follow the foam.
I bought a roll of some kind of filler like a rope of flexible round seal about 1/2 or 5/8" in diameter and some goop from Home Depot. Sorry, I don't know the names.
Stuff the rope into the crack then squeeze the goop on top to fill to the surface. This basically makes an expansion joint. I think you need something flexible since the gap is likely to move more during the seasons or with settling.
In that the sidewalk is "floating away" from the garage would probably indicate a problem that might persist. I suspect the base, under the sidewalk, has some issues. The base might be insufficiently constructed and is collapsing or deteriorating, causing the concrete to shift.
Filling the crack might help for a while, but a separation that wide would lead me to think the sidewalk will continue to separate. The question is whether they want a temporary fix or a permanent one.
Is that rather than the slab moving, is when the house is on a sloped lot, with the front uphill to the street, where you enter on the second floor. If the builder didn't use dead-men buried up the slope to prevent the backfill from pushing the foundation wall inward, the wall can be tilting over from the pressure.
Usually you can find some crack in the wall. If there is a basement, or high crawl space, check that wall for plumb. My bet is that it will be leaning in by the amount showing on the outside. This is a lot more likely on a concrete block wall with a few filled cavities than a solid poured concrete wall. It doesn't take a lot to push the block wall over, and the mud-sill connection isn't enough to prevent this.
I would expect Barry has seen plenty of this and could share some experience. If this is the cause, the home owner will not be happy to hear it.
I wouldn't rule that out, but hopefully it's not the foundation. It's not uncommon to see poor quality concrete work around houses. Insufficient compaction, insufficient base etc are often culprits. Drainage can also play a part.
Regardless of whether it's the sidewalk of the foundation, it sounds like it might be a good idea to have the problem looked at. You might wait to fill the gap until someone with structural knowledge can look at it and offer advice.
This needs to be looked at with an open mind. It could be the walk migrating away from the house, because walks are often very poorly done on residences.
It could also be the wall tipping inward, especially if there is a basement.
In this case, it is desirable that the walk is the culprit. Its a lot cheaper and easier to address than the wall of the house.
Sealing the crack is probably a good idea in either case. Keeping water out of the crawl space or basement is a good idea. Also, its a good idea to keep water out from under the walk also. It is important that the water drain away form the house. Make sure the walk slopes away. If not, you may have a funnel and sealing the crack won't help much.
Clean out the crack, install a piece of backer rod and caulk the crack with soft flexible caulk. The caulk should have a cross section like a bow-tie. Fairly wide ends to stick tightly to the house and walk and a tin center section to flex and stretch. You do not want a big thick wad of caulk. Check with a swimming pool company that installs and maintains in-ground pools and see what they use on the coping. Thiokol and Pecora make it as well as others.
Sealing the crack may help and give you time to figure out why the crack is there.
The terrain is flat and the foundation is OK. The house was built in the 1980s and the current owners have there just about 4 years. The "porch" slab by the front door has sagged on the side away from the house, about 3-3/4" as I recall. When they bought the house, the corner post was hanging by a nail. I built a wedge to go under the post, then fashioned a new set of skirting boards for the bottom of the post to match the slope of the cement. Three- plus years later the post is still solid, so I know the slab isn't moving any more.
So the walk way I think has moved away from the garage because of the same settling of the soil or whatever caused the porch slab to shift. It's not constant motion. And the drainage is ok, and the gutters and down spout are in good condition. But when I saw weeds growing there, we'll that's cause for concern. Root damage and freezing water may not destroy the place, but certainly are not helpful.
Thanks for the suggestions. I thought of "great stuff" but was unsure of it's durability. Same for simplyl caulking the gap. But you all have given me some good ideas.
This is encouraging. If the settlement occurred early on and seems to have stabilized, it was probably that, settlement. One of those rules of thumb that probably should not be considered fact is that ordinary settlement (if such exists) occurs at a decelerating rate. Something like 90% of what is going to happen occurs in the first 10% of the time. So, 90% of what was going to happen in the first ten years occurred in the first year. And 90% of what was going to happen in the first 100 years occurred in the first 10, so you may be good to go. Especially if it slopes away from the house and drains well. Kill the weeds, seal the crack with something flexible and nearly permanent and don't look back.
This sounds like the builder poured the concrete on poorly compacted fill and it has consolidated over the years.
There are many things that could change this. Trash under the slabs is common. Builders fill the stoop with debris including wood and it rots away and is a perfect home for termites. A water line fails and leaks and washes soil form under the slab. Water freezes and thaws and pushes things around. Water leaks under the slab and liquefies the soil and the slabs sides away. I'm sure there are more.
PS, I don't have a lot of experience with Great Stuff outdoors, but I have seen it use and it degrades in sunlight and turn sort of rusty red. And, once it sets its not very flexible. While it would be quick and easy, I don't think it would be good in this application.
NP-1 made by Sonolastic. Masterseal is another brand name, though I have no experience with that brand. The product is sold in caulk tubes, and is available in several viscosities so it will hold on a vertical surface or flow and self level in to a horizontal one. Widely available at major retailers like Wally World.
I would recommend "Semi Self Leveling" version in concrete color. Might need to go to an industrial supplier for that specific version, dunno. Clean the gap thoroughly. You can also purchase foam backer rod to fill the majority of the void, leaving a 1/2" deep channel for the product to be installed.
As a facility manager, prevention is key, and we use the product extensively wherever we are trying to limit moisture encroachment, or to simply fill a void. It will remain flexible for years.
While I applaud your concern, such a crack between the home foundation and the sidewalk isn't uncommon up here in the snow belt. Indeed, it is more like the norm.
AZ, When I was a young carpenter, I worked for a while with some others that were pretty lax with their measuring and cutting. They would nail up some pretty loosely fitting boards. One of their favorite sayings while doing so, was that "If God didn't love us, he wouldn't have given us 1/2" caulk." Well, I'm of the opinion that a half inch is actually too large for caulk.
Back then, we didn't have Great Stuff or any of the other brands, but their specs claim you can fill gaps up to 3", so using their reasoning, God must love us six times as much as when I was younger. ;>)
As for using it outdoors, I've used it for lots of things, like shooting in under dry laid stones on steep slopes making walking paths behind my sister's house. It will break down in Sunlight like any poly, but it does paint well, so you can make it look better by painting plus protect it from degradation.
