Cutting coves????
Cutting coves????
Cutting coves????
A friend of my son has asked for some sanding blocks with coves cut in them. He wants the coves to be specific radii. So far they appear to be 5/8" and smaller. He is sending the specifics later.
To make matters worse, the "original" block is about 1 1/2" by 1 1/2" by 2 1/4". In a effort to be helpful he provided some walnut blocks to make them out of. The original appears to be basswood.
How do you cut coves accurately? I really don't want to go buy shaper cutters or router bits to make a hand full of little blocks.
Any suggestions on how to hold the little blocks while I cut them? (I'm thinking of cutting them in a bigger piece and trade him.)
Re: Cutting coves????
Doug Wolf
If I understand you correctly, I would stand the block on its edge and use a forstner bit of the correct diameter to drill through the block. You would have to clamp another piece of wood to the block so you could drill on the split then you would have a cove on each piece.
Kneale Brownson
Kneale Brownson
Are the coves to be on the ends of the blocks or run a length?
What's their purpose?
If along the length, I'd router a wider board and cut off.
AZ in Colorado Springs
Similar to what Doug suggested, drill a hole lengthwise thru the block then rip the block in half. Two sanding blocks for each radius.
Router bit, router plane, angle fence on table saw
While waiting for more information I went into the shop and started piddling.
I scoped out the block he sent and the coves appeared to be 1/2 and 1 1/8". The walnut blocks were all different sizes and shapes But all somewhere between two and three inches on the biggest dimension. I decided to use some redwood scraps I had.
I had a half inch shaper cutter So I cut a cove down both edges of a 2 x 4 block and then cut it down to about 3" long and end drill through it with a Forcner bit and ripped the block. Made ten while I was at it. Ruined one.
An hour later my son sends me a text explaining what the guy really wanted was about three of each with 1/2", 5/8" 3/4" and 1" coves, most any length and width. The reason the one he sent had a 1 1/8" groove was it was worn out and supposed to be 1".
Thanks for the help. Next time I will wait for better instructions. I broke one of my "rules". Don't leave until you know where you are going. Back in the shop with a new plan.
