Hex Accessories
Hex Accessories
Hex Accessories
Doug Reynolds
My Guild and I are making some toys for charity which require hex-shaped accessories such as a school bus stop sign. As I am making a batch of these, does anyone have suggestions for how to make hex-shaped items in production mode? I don't foresee wood thickness being greater than 3/4" and, usually thinner. I looked on the Beall threader web site regarding hex nuts but did not find a jig for making the nuts. I am, however, computer challenged. TIA, Doug in sunny Seattle where we are setting record heats of 88 degrees!
Re: Hex Accessories
Re: Hex Accessories
Maybe I am confused but a stop sign is an octagon, not a hexagon.
Re: Hex Accessories
Rip long sticks
Dick Coers
Then end grain slice to proper thickness. I made up a fixture to cut the hex nuts for threading. I did that so the hole would be centered. Don't see the need for that to make toy parts.
Re: Hex Accessories
Re: Hex Accessories
Tony - Memphis
Ha, we are at 81° and calling it a serious cool down!
I had a similar idea as mentioned....I made a giant pencil a while back. I just marked a dowel on the late using an index wheel every 'x°,' then I used a plane to take down the flats. Quick and easy. Then you could just slice the work piece. Could also build a carrier jig to do it on the bandsaw (folks often do that to remove the corners before turning a spindle blank).
If you really want to use the tablesaw, a jig could be made on a flat carrier piece with just a couple of scraps a fences to hold the piece at the correct angle. Or just freehand them on the bandsaw and clean up with a plane or sandpaper.
Tony
