REAL MILK PAINT
OT Asphalt drive repairs?
Tom
Looking for a product to repair 3/4"+ wide cracks in the drive. Saw a You Tube video about a "rope" that you stuff in the crack then go over it with a torch.
Anyone have any suggestions??
Thanks!
Re: OT Asphalt drive repairs?
According to the guys who did my driveway . . . cracks in blacktop can't be repaired. You can fill them with whatever, but the crack's still there and will reopen in a season or two. The ground moves up and down with varying water content, root movement, and freeze/thaw cycles. Ain't nothing you can do about it.
I'm with Mark.
Gary Smyth
The filler rod may marginally help -- and might even limit/delay some further short term deterioration. But as is stated about asphalt. "Once it goes crack, it can never go back".
One of the many hats I wore in my previous career at the University of Illinois was overseeing the repairs to the parking facilities (and construction of new ones). Asphalt, while seemingly a hard surface, is actually a pliable surface. Cracking happens for various reasons, but is often generated from the base, up. There is no way to "heal" a crack. Whatever you fill the crack with will not "fix" the crack itself. The reason for filling the crack is for safety and to retard water. Water is more of a problem where there is winter conditions. (freeze/thaw).
In all my years, we never seal coated asphalt. Seal coating is mostly for aesthetics and does little else. If at some point you decide to overlay your drive with new asphalt, be sure that a geotextile mat is applied over the cracks first. Otherwise the cracks you are covering will come back. It's called "reflective cracking".
Good luck with your repairs.
T.
A Note On Black Seal
Unless the formula has changed, driveway sealer was shown to be a significant carcinogen that, once applied, gets tracked into the home. It's sold to homeowners on the lie that it will prevent cracking etc. It doesn't. Consider the health of your family before making your driveway look "nice."
This worked for me
Tom Dunlap
When I ran my tree care company we occasionally damaged a driveway. Ooops!
I got the suggestion for a crack filler that seemed to work pretty well. The reason I say it worked is that I went back to more than one of the repair jobs and the crack wasn't open again...and...the client was content.
The recipe consisted of using a quart or gallon jug of liquid seal/crack filler and as much sandblasting sand as needed to make a mix that would hold a crisp edge like thick brownies or cake frosting when I mixed it with a spatula.
Use compressed air to clean things up and do the repair on a hot day. Putty the mix in and tamp/hammer it home.
You can't go wrong or make things worse. Like I said, clients were OK with the repair too. Whew!
Re: This worked for me
Tom
Tom,
I will try it! I just finished doing some sandblasting and I have a bunch of media left over. Thanks!!
use bitumen emulsion
ian neuhaus
you need a dry day
a clean crack
and enough bitumen emulsion and graded sand or grit to make a dough like mix -- alternatively u vcan buy a product known locally as "cold mix".
paint the sides of the crack with emulsion, then follow up with the emulsion / grit mix.
tamp it and cover with dry sand or grit
The repair is mostly about preventing water from using the crack to wet-up the material below the asphalt.
