Fastcap Speed Skate
Fastcap Speed Skate
Fastcap Speed Skate
Stuart Johnson
Handling 4x8 sheets of plywood has gotten harder in the last few years since they seem to have doubled the weight. I bought one of the Fastcap speed skates and can say it works as advertised.
No interest in the company but thought I would pass this on.
Re: Fastcap Speed Skate
I would have a hard time paying for that.
Dick Coers
Looks like a super easy project for the shop. If I had that much room in the shop, I'd make one.
Re: I would have a hard time paying for that.
Ha! At the moment, getting a sheet of plywood from one end of my shop to the other almost requires two people - not for the lifting but to snake it around all the stuff on the floor.
I noticed sheet goods getting heavier too after I got over 65. When building my shop I became a believer in the bright orange sheet goods carrying handles I got from Home Depot. It's not the weight but the grip.
Decent idea never exploited.  Another
Gary Smyth
opportunity never considered. Almost twenty years ago I thought that some help with sheet goods could be made a bit easier. Old skateboards seemed to be one workable alternative. Around here if you go to ten house sales or flea markets you will find three skateboards. Usually a sawbuck or less. I've done this for a while so look for the flattest board you can find, and get the most flexible truck and best wheel bearings. If a wheel doesn't rotate at least five times with a swipe of the hand, look some more. Good truck wheels will spin at least triple that number.
You can use as is or remove the trucks and mount on a base of your choice. You can also mount homebuilt guides on top of the board (they have seen their last skate park) to keep the sheets from sliding as they travel. If you choose to use one truck set, make another with the other truck and give as gift. NOTE: Good trucks, new, can cost in the range of $75. If you decide to go this route and find a good board for say, $15 its a bargain. At least compare to the cost of commercial sheet good wheels.
Re: Decent idea never exploited.  Another
You should submit that idea to one of the WW magazines. I would judge it a winner.
Keith Newton
Those wheels are too small to be useful in my shop. First I have ramps at both doors, so it would get hung on the ends before getting in the door. And second, the smaller the wheels, the smaller the obstacle needs to be to become a chock. That would be a whole lot better with about 6" D soft wheels.
Something I did before installing the track on the ceiling with the hoist and vacuum pad, was to make a simple fixture to drop over the blade of my hand-cart. When I laid the cart on the floor with the blade sticking up, it was a scrap of plywood which stuck on up about another 2' above the blade with a 1.5" slot for the sheet to slide into, then on up the handle. The dolly stays on it's back or horizontal when loaded, so when the sheet is close to centered, it is just a matter of keeping it balanced, as I pushed it around. The soft 12" wheels will easily jump over scraps, hoses or thresholds, or even roll through your lawn.
When I roll it up to the TS, I just set the end up by the fence, still on edge, then go to the other end to lift out of the slot, and let it roll over flat, then feed it over through the saw. There was never any need to lift over half the weight of the sheet.
