Beolube
Beolube
Beolube
Charles Yawn
Just saw an ad for this stuff. Any opinions out there about it's real usefulness?
Use Boelube to make drill bits last longer. Whenever you drill multiple holes in metal, stick the bit into the lube before starting each one. It also works on metal-cutting reciprocating and band saw blades. It reduces friction, which makes the cutting edge last longer. The product number is 70200-13, and it is available from multiple online retailers.
Re: Beolube
Re: Beolube
If it is that wax stick I use it for screws where it works wonders for making them drive easier.
Re: Beolube
Kneale Brownson
I use cutting oil when working on metal
Re: Beolube
Re: Beolube
Jay Lombardo
Drilled thousands of holes in steel and stainless steel electrical troughs for various sized conduits. Mostly with hole saws. Over the years I found that a combination of a cobalt pilot bit and a carbide tipped hole saw was by far the best and longest lasting. The secret sauce of the operation was "Tap Magic" cutting and tapping fluid, best stuff ever!!
