I was posting about the pile of 3/8" thick sticks I bought and how they might be used for Loose or Floating tenons.
Jesse posted about using and End Mill and how they were cheaper. Having looked them up, they are dramatically cheaper. Why? Do they work as well in wood as router bits? Whats the deal?
Also, Dick pointed out in the post below that trying to cut aluminum with wood working tools is potentially dangerous. Thank you Dick. I had become to cavalier about cutting aluminum. Don't do it much, but I do occasionally. I ripped down a small angle the other day to repair and reinforce a door jamb. In searching for router bits I found ones designed for cutting aluminum. At least I assume an aluminum bit is meant for cutting aluminum, not made out of it. Thanks again.
End mills are cheaper because they are usually high speed or cobalt steel rather than carbide and are less expensive to grind. There may also be some economy of scale in producing them as the machining supply segment is much larger than the woodworking one.
Wood bit manufacturers may optimize the cutting angles for wood, but end mills for metals do work well enough for cutting wood.
One big difference is that while router bits often have a shank size different from the cutter size, a 3/8 endmill will have a 3/8 inch shank, so you need a 3/8 inch collett.
Maybe another difference is that endmills are designed to run at slower rpms. Many advise that you should run your router at a slower speed. I usually ignore that and never noticed any problem.
John is right about the angles, but endmills will cut a nice smooth wall on your mortise.
The price difference between bits and endmills gets huge when you are looking for long ones.
It's a calculation of speed, feeds, and number of flutes. End mills are made to cut steel, others to cut aluminum, and also specialty. Steel cutting end mills may have a less aggressive, shallow depth spiral because it has to lift out a small chip, and need to be stronger for less flex in a hard cut. Aluminum end mills have a more aggressive spiral and deeper flute to lift out larger chips and curls. Not all end mills are sharpened to the center, just like straight flute router bits, so can't be used in plunge cuts.
I use Center-cutting end mills almost exclusively in my JDS Multi-Router. They make very clean cuts, and the TiN coated ones last almost as well as Carbide. I get mine from Enco for about half the cost of router bits.
I use end mills in my milling machine to cut steel, brass, aluminum, plastic (acrylic, HDPE, nylon, etc), and wood. End mills cut wood very well, especially hard, fine-grained wood like many exotics, dogwood, persimmon, hard maple, etc. I used a nice chunk of lignum vitae to fabricate a missing component for my Robland sliding table, using an end mill, a boring bar, rotary table, and a drill press. It works perfectly.
End mills are great for cutting a short slot in the center of a piece of something. Great for milling a clean edge. Reasonably good for flattening a top surface.
You can buy end mills that will cut in the center so you can kind of drill holes with them (mostly to drill down to the depth you need to mill to) or not center cutting. I have some with two cutting edges on the end and some with four.
Small diameter end mills often have a shank larger than the cutting section. (see pic below) One set I have uses 3/8" shanks on mill diameters from 3/8 down to 1/8". (1/8" end mills are easy to break - I know from experience) Larger mills generally have shanks the same diameter as the cutter. The diameters available are limited compared to diameters you can find in drill bits.
I have end mills made from solid carbide, HSS, cobalt, and some coated with titanium nitride. Big surprise: high quality end mills cost more. Junk mills are cheap. Even a junk mill should last a long time on wood or plastic.
I made this banding iron from a chunk of bonze using mostly an end mill and a Dremel.
and I don't have a 3/8" collet. I have 1/2" and 1/4" and an adapter/sleeve that converts the 1/2" to 8mm. A Collet for the Festool router is $44. That green Koolaid ain't cheap! Where does one get one of the sleeves that converts from 1/2" to 3/8"? Seems that should be more reasonable.
I went to Enco and looked at end mills. A somewhat confusing variety., but then I am easily confused. Did anyone else notice that Enco is becoming MSC?
It seems I have endless possibilities. I could get the 3/8" collet or the sleeve if such a thing exists and use 3/8 end mills. I could get 8mm end mills and adjust my cutting pattern to produce a 3/8" slot. I could use router bits with a half inch shank and a 3/8" cutter. Etc.
If I get a good end mill, how many slots should it cut? (How high IS up?) If I am making 1" deep by 7/8 X 3/8" mortises, should I get a dozen or a hundred or a thousand out of the bit befor I have to switch it out?
The end mill in the Domino works for plung cutting mortises because the bit oscillates from side to side as it rotates and plunges. You can make a real mess of the cut and the mill if you plunge too forcefully.
Woodcraft sells sleeves. Whiteside makes high quality ones.
Enco bought MSC a numbesr of years ago. They should continue to give you the Enco prices if you you convert your account using their procedures, but not if you oqpen a new MSC account.
To dispell sime of your confuusion, (with a bit if study), get a copy of Machenery's Handbook. Older editions are inexpensive on used book market. Toolbox edition just fits in a special drawer in Gerstner machinist tool boxes
The problem for this exercise is that only one of them has a plunge base. That's the Festool one. My other plunge base one was stolen In the Great Tool Robbery a few years ago.
I'll take a stab at your question on how long an end mill will last. Before I got my Domino, I used a 3/8 endmill to cut mortises. A set of 6 chairs, a dining table, a shop table, and a bed among other things were made this way. I figure 300 mortise for the pieces mentioned above, and the end mill still cut like butter.
So the answer is definitely in the hundreds. I would say probably about the same life you would get from a router bit.
I did lower the speed on my router to its lowest speed.
I went to a tool reseller today and bought some bits and end mills. This "company" buys closeout stuff and resells it. They had a box about 14" square about 6" deep of various bits. Let me take my time and sort them out and sold any I wanted for $10 each. It was a weird assortment. I got a 1/2" hollow chisel and bit set for my mortiser. About 5 bits that are either 3/8" or 1/2" shank reduced to 3/8". Two more that are the compression bits that cut up on the bottom and down on the top. And one that is 1/2" shank and a 1" cutter. I am in "bidness".
This guy caters to industrial customers. This box of router bits is not his "thing" and I am not his customer. I am tempted to go back and offer him $200 or something for the whole box. (Can you say "Kid in a Candy Store?)
I made a little template this morning and cut a double mortise in a table leg and rail. Used a router bit I already had. Worked great for a practice run. These new bits should work even better. They are really SHARP.
I cut mortises about an inch deep. With the new bits I should be able to make them 1 1/4" deep.
I destroyed my first router, because no one explained about center cutting plunge router bits. I overheated the upper shaft bearing and melted to top of the case. My next router was a PC 690 with a cast aluminum case. It still works very reliably, and is the only reason I've not bought a Festool.
