Aluminum cutting question
Thomas E Norton
I may need to fabricate a few things out of 1/4" thick 6061T6 aluminum.. So my question is what tools in my shop can I use?
Thanks!
Re: Aluminum cutting question
Larry
Table Saw with an aluminum cutting blade, or chop saw with an aluminum cutting blade
Thomas E Norton
How about router work for curves and slots?
What woodworking tools?
Dick Coers
I guess you are asking what woodworking tools and machines? Remember, you are using cutting tools that are the wrong cutter geometry and way too high of speed. So every time you try to cut, you are taking a chance that the aluminum will over heat and "weld" itself to the cutter or blade. Slow feeds and some kind of lubricant helps. Do it wrong with a miter saw, and you get a crazy kickback! Same pretty much goes for the table saw. Do it wrong with the router, and you will probably just get a messed up slot. Maybe a broken bit. If you attempt it, NEVER hold the stop with just your hands. A kick back with wood is dangerous, a kickback with aluminum can be deadly. You'll get plenty of just go ahead because I did it. But honestly, we don't know your skills, sharpness of your cutters, and we don't what kind of life insurance policy you have.
John in NM
I've done it with a router, years ago, but its awful.
I never had any of the problems Dick mentions, but it is loud and annoying, and if you're cutting with a router you are going to get very hot and sharp chips in your gloves, up your sleeves, down the collar of your shirt.... horrible.
We used to wear ear plugs with muffs over them and safety glasses with a full face shield over them, and gloves with the wrists taped for any kind of metal + router work.
Chop saw isn't so bad, bandsaw with a fine tooth blade is very tame.
Re: What woodworking tools?
Larry
I have cut up to 1" aluminum on Table Saw with an aluminum cutting blade.
Go slow, you will feel the right speed. Clean out the sawdust from the table saw. You don't want any fires!
more info?
Thomas,
I see some assumptions here about what kinds of cuts you need to make. Maybe you could simply describe what you want to make and perhaps get some useful advice. Also, you say you want to know what tools in your shop you can use. You might list the tools you have in your shop.
Do you need curves, straight edges, round holes? Machined to tight tolerances or is an approximate size ok? Do you need to join pieces?
Can you make your cuts with a jig saw or reciprocating saw? You won't get a perfectly machined edge but it is extremely safe. Either will cut 1/4" 6061.
Hand files work on aluminum but I use special files made for it. Normal files made for steel will load up and be difficult to clean.
Belt and disk sanders work OK.
Aluminum will load up a bench grinder and make a mess. A wire brush on a bench grinder is OK.
I know many have used a table saw to cut aluminum but it scares me. Using a jointer or planer would be insane. A bandsaw with an appropriate blade works just fine on thin stock (like 1/4") and doesn't scare me.
Portable drill and drill press work well. You can drill, countersink, and tap aluminum easily.
I have crosscut extruded aluminum with a carbide toothed blade in my sliding compound saw. I clamped it tightly. I only made a couple of cuts. Note that under certain circumstances aluminum can "weld" itself to a carbide cutting tool and cause a big mess, a broken tool, and a possible injury. My machining guides say to use HSS steel instead of carbide on the mill and metal lathe.
For precision parts you might find a buddy or a new friend near you who has a milling machine and metal lathe and metal-cutting saws. Aluminum is very easy to work compared to steel.
BTW, this probably won't help for your project but just so you know: you can easily use high speed steel tools to cut aluminum with very light cuts. I have turned a number of things from aluminum (and brass) using Thompson spindle gouges, skews, and other tools on a wood lathe.
Agree. been there, done that
All aluminum is not created equal. Aluminum intended to be machined is alloyed to make it less sticky. What is the composition of your aluminum?
If things go wrong and the aluminum welds, galls or whatever it is to be called the results make wood kick backs seem tame. I have a metal cutting blade with aluminum fused to some of the teeth. A wood saw speed is too high, at lest for what I was cutting. One might get by with 1/8" aluminum. I would not want to be in the neighborhood if someone was working 1/4" with wood tools.
Bandsaw and fine toothed blade is ok.
Re: Agree. been there, done that
John McGaw
Sometimes what you see is not what you get. I had some regular 'honeycomb' type shades that had been measured to fit outside the frames and decided that they would be better inside. I examined them and saw aluminum extrusions for the top and bottom bars and paper between so removed the plastic end-caps from the non-string ends and then taped them closed very firmly and proceeded to the Dewalt CMS equipped with a Forrest Chopmaster 12" blade and carefully and slowly made the cut. It seemed to go OK and was quite clean. Only when the time came to untape and re-cap the ends did I find out that there were bars of iron inserted into the bottom extrusion for weight. Scared the crap out of me but a close examination of the blade revealed no serious damage, not even a chipped tooth, and the blade cut wood perfectly afterward and went on for quite a while before being resharpened. I do not suggest cutting iron with WW tools but can state that the teeth on a saw blade are pretty strong and clearly harder than iron.
Oh, on the second blind I took the time to remove the end weight.
John in NM
The 6061 he plans to use is a good alloy for machining work, it won't gall as bad as the stuff you get at the hardware store.
Aside from the noise and hot chips, cutting it with a router won't present great problems. Any cutting with a saw blade (chop, table, or band) benefits from the correct tooth geometry - a low or negative hook angle, depending on the tool used.
William Duffield
Another option for straight cots is a tracksaw with a metal cutting blade. The Festool is variable speed, so it can be slowed down for less heat.
For curves, I would use a nibbler, e.
g., from Bad Dog Tools.
Re: more info?
William Duffield
If you need to file but don'thave an AL file, you can preload the file with chalk to make it easier to clean.
Cutting steel did absolutely nothing to it?
Dick Coers
Don't buy it. If that was the case, a carbide tooth blade would last indefinitely just cutting wood. I've had a Forrest blades sharpened many times, and they are always better when they come back. Never touched steel.
I'll buy it...
John in NM
Cutting through a tiny amount of mild steel like that could go just fine with no visible damage to the teeth. That is not to say the blade wouldn't be dulled by such action, just that you probably couldn't see it under close visual inspection.
Now if he'd used a blade that way for several hours I wouldn't buy it, but one or two cuts is little worse than hitting the odd drywall screw or something. Done that often enough.
Re: Cutting steel did absolutely nothing to it?
John McGaw
I never claimed that nothing happened to the blade -- only that there was no visible defect and it cut wood very well after the incident. I'm sure that if I had taken a microscope to each tooth before and after there would have been differences. Keep in mind that this was soft iron put in for weight -- they weren't splurging on some hard heat-treated alloy -- and the cross section was maybe 1-1/4" X 3/8". I still have the same blade today and after one resharpening it still serves me well.
I have cut a number of pieces of steel with various blades. I have cut more than one staple (the type they staple labels on lumber piles) with no apparent damage to my Forrest WWII. I hit a Kreg Screw with it and ruined several teeth. Those screws are hardened. This is a serious advantage to biscuits. With a circular saw, I "ripped" a 12d framing nail with a cheap carbide tipped blade. Wasn't good for it but the blade had some remaining life. With similar blades I have cross cut numerous framing nails. Sometimes you win and sometimes you lose a few teeth.
I have seen a demonstration several times of a carbide tipped blade made for cutting steel. The cut angle iron and plate. Seemed to work well enough without much damage to the blade, but it was terrifying. Sparks and metal slivers flying everywhere. You couldn't wear enough eye protection and PPG for me to use it.
I like my saw blades just like my plane blades
Dick Coers
Razor sharp! When you said it cut perfectly in the original post, I related that to what I think is a perfect cut. I assume there lies the problem, your perfect and mine aren't the same.
Re: I like my saw blades just like my plane blades
John McGaw
Quite possibly. I am but a humble wood butcher and if a cut looks and feels clean and doesn't show burning or require unusual force I accept it as clean. My CMS is as likely to be used for framing lumber nearly as often as it is for 'good' wood. Even PVC pipe is not off limits to me when necessity dictates.
PVC and steel are a lot different! LOL
Re: Aluminum cutting question router?
I always used Kerosene for Drilling and tapping aluminum, I would assume (I know what assuming can get you) that it would work well as a lubricant for a router bit or end mill.
If you wish Tap Magic does make a commercial lubricant, I have used it (for drilling and tapping), but it didn't seem to have any advantage over plain Kerosene. The lubricant prevents the aluminum from "welding" to the cutting tool.
Aluminum does require slow speed for cutting tools, don't know if a router could be slow enough. I would certainly use a 2 flute cutter VS a 4 flute. As Bill has stated, there are several types of Aluminum ~ some have additives to enhance machining ~ some don't. The difference can be like cutting Balsa wood VS oak!
