Installing drawer slips
PIC 1
A drawer slip is a feature of English drawers. It is the “extra” piece seen in Picture 1. Its function is to provide additional bearing surface enabling thinner drawer sides and a lighter weight drawer. It also has the groove that captures the drawer bottom.
PIC 2
Slips do not have to add significant time to drawer construction. I prepare 5/4 poplar blanks about 2 ¼” wide. The groove for the drawer is milled into 4 sides of the blank and the corners rounded. This piece is then sawed into 4 slips.
PIC 3
Installing the slips is easy and reliable. I have on hand a piece of wood, the walnut piece in the picture, that fits snugly into the groove. This piece functions as a temporary bottom to align the slip. The slip-to-be is positioned with this alignment aid and a line drawn across the drawer side to mark the waste to be removed from the slip. Waste is trimmed almost to this line by any means handy. I often use the jointer.
PIC 4
Glue is applied to the back of the slip, it is aligned with the alignment block and clamped in place. The clamps don’t have to stay on long; 15-20 minutes is sufficient. When the glue is more cured, about an hour, the slip is planed flush with the drawer bottom.
PIC 5
The finished result is shown in Picture 5. A subtle benefit of slip installation as I have shown it is that the drawer grooves will be in perfect alignment. Perfect alignment is not always achieved when the grooves are cut in the drawer sides before assembly.
