I was at a freight auction and bought a pallet of "wooden sticks". Actually there appears to be about a thousand pieces of wood 15 3/4" long, 3/8" thick and 7/8" wide with fully radius edges. I'm pretty sure they are beech. I don't have a micrometer to measure them with, so those dimensions are from using a tape.
I bought them on a whim. Any idea what they might be useful for? (Loose tenons??)
I don't know, but if you find yourself with an excess what I do is contact the art teachers in the local public school. The are extremely grateful for unusual supplies.
I've taken styrofoam, wood, and trailer load of 10000 small cardboard boxes. I'm cutting leftover 1/2" plywood into some equal and some random sizes, good for painting on, etc. Always feed the creativity.
I don't have a clue about the sticks, can't help you there.
But:
>> "I don't have a micrometer...."
Barry, Barry, how do you survive all these years without a caliper (no, you don't need a micrometer)?
If you have a Harborfreight store in the neighborhood, you can get a 6" caliper on sale almost every other week for about $10. Or even a "utility" caliper for less than $4 is very useful.
I actually have one similar to that, and a micrometer......at home in the shop.....its just that I am not there. When I get home I will measure them more carefully.
I just think this might be the start to a career that includes lots of loose tenon joinery.
3/8 inch is a good thickness for loose tenons. I forget whether your Festool tool cache had a router, but some Festool routers will accept a 3/8 collet. This is worth getting because it can handle a 3/8 inch end mill - which is much cheaper than an equivalent router bit, especially for large depth of cut.
That used to be my go-to mortise and tenon setup before I got a Domino.
My sister bought a kitchen utensil which is a little flat box, with slats about that size that you can set hot pots or pie / casseroles on right out of the oven or burner, without worrying about counter tops.
Everybody you know should be getting one of these for christmas this year,,,,,,,,,,,,,,, so turn that computer off and get busy. ;>)
Sounds like the stuff they toss in the bottom of a vat when they brew Budwiser. I know a place in Millington TN that used to cut them for AB. That was years ago.
I did get a Festool router and also have about six others. I will have to check on the collet. Not sure I got a 3/8 collet. I did get a 3/8" bit that has tow straight flutes and a half inch shank. That may be a start. Now to figure out some sort of gig or gigs. I stacked up a bunch of the sticks and they are 3/8 by 7/8. It appears I have a life time supply of floating tenons. Any advice would be appreciated. For example, how deep do you make the mortices?
They have opened a craft brewing place behind the office. Perhaps they need some beech wood to improve their product and I can work a trade. I just wish I liked beer. OH! Why couldn't it have been an ice cream place or a steak place?
Hey Barry. You are almost there! I use a simple jig that will guide a router bushing (Porter Cable bushings should fit on the insert for your festool router or just about any other brand). Just route a groove the diameter of the bushing and a little longer than the width you want the mortise to be (to compensate for the bushing and the distance between the bushing and the bit). I make a bunch of these on 1/4 or 1/2 mdf with a good deal of space between them. Then to fit them to a particular joint,cut the groove out with a width on one side a little wider that the distance from the edge to the mortise. Clamp the groove onto the workpiece where the mortise will be, then take a piece of scrap for a fence, set it against the workpiece and the mdf, and shoot it a couple of brads. voila! All you have to do is to clamp the fence to the workpiece and route, taking several light passes. Sounds way harder than it is.
As for mortise depth, I use about the same I would with regular mortises. A lot of my furniture work winds up with 1 1/4 or 1 1/2 deep mortises.
This is almost hysterical. I bought a box of sticks, about a thousand of them for a penny a piece and now I am trying to change everything I thought I knew about building furniture to use them and not waste them.
