Re: Twists
Andrew F in Australia
HI Matt,
It's useful, but a bit harder to work than your natives. Some species are pretty, others are pretty ugly. Gum veins and roey/interlocked grain.
A quick google search said that it's likely to be Tasmanian Blue Gum. If it's Tassie Blue Gum, it's not a good timber, see the workability info here. http://www.tastimber.tas.gov.au/species/pdfs/bluegum.pdf http://www.fpc.wa.gov.au/node/976
Overall, Eucalypt needs to be cut carefully and dried properly. It can be prone to wind/twist, especially if the tree is young.
Our most common species ("Tassie Oak," a mix of four species) must be quarter cut to avoid honeycombing, checking and warping on seasoning. Anything that's not quarter cut will warp and check substantially.
If you want to try using it, ensure it's quarter cut. As an equivalent, US Mesquite is a bit harder, Walnut is significantly softer. US Oak is similar in hardness and workability, but Eucalypt splinters far easier and cuts need to be delineated by a knife line. I find that tools blunt far quicker in Eucalypt than they do in any imported timber. Hickory is pretty similar to our Spotted Gum as a handle timber, roey grain and difficult to work without tearout.
Final word from the US forest products service. http://www.na.fs.fed.us/spfo/pubs/silvics_manual/volume_2/eucalyptus/globulus.htm
Hope that this helps.
A
