Performax 16-32 belt length?
Rich Pearson in Mill Creek, WA
I am off by a bit on length and I hate to burn through a bulk roll experimenting.
Does anyone have a factory belt they could measure for the exact length?
Thanks in advance
Re: Performax 16-32 belt length?
Why not buy one and use it as a pattern?
I find trimming the edge of the angle perhaps more important than the exact length. If the belt is too long, its also too wide and tends to lap over itself as it runs on the drum. It's better for the belt to have gaps than to over lap itself. If the angle is wrong and you don't fold the end properly the end will wear off. As I recall, the end next to the motor takes the beating, but it may be whichever end is not laying flat on the drum. I have repaired the end next the motor with strapping tape to get the remainder of the life out of the belt. I find it good to wrap the belt from the outside in and when it is lying flat and tight on the drum to fold the end of the belt where it goes through the slot, except to make the crease about a 1/4" short of the opening so the clamp pulls it tight.
Am I the only one that finds this system to be fiddly and tedious?
Gary Smyth
If you go to a browser and type in "Performax 16-32 belt length" a screen comes up saying 16 x 43 1/2. The same screen offers a manual and that ought to provide the specs. You Tube has several videos on the 16-32. I did not view all of those. One, #31 - SandSmart Upgrade to a Performax 16-32 Drum Sander talks about feed motor but there are others. Eventhough JET is now Performax can't JET customer service tell you what you want to know?
Clifton C
Measured two, both 91 inches
c
Ooops, 43 1/2" is conveyor belt size
