Saber saw blades for clean cutting
c a gernentz
What kind of saber saw blades do you use on plywood, need to cut some fancy cuts in center and any blade I have ever used would destroy it. There has to be some kind of finish blade out there that will cut kind of smooth. thanks for any help
Re: Saber saw blades for clean cutting
I saw some down cutting blades for laminate at Lowe's the other day. Wonder how well they would work. Perhaps the top side would be clean. Or cut your piece form the bottom? Or sandwich your piece and then cut it?
Precision ground with little or not set
Dick Coers
is what you need. Higher tooth count also helps. Both of those features will make for slower cutting. I also cut through packing or masking tape to reinforce the wood grain. If the cut is really critical, I score the wood with an X-acto blade and cut just to the side of that score line.
Re: Saber saw blades for clean cutting *LINK*
Clifton C
I use, Bosch T101BR blades, It's reverse tooth so it cuts on the down stroke. The "set" is ground into the blade so the front (tooth side) is wider then the back. Sort of like the old hollow ground plywood blades. It is a nice smooth cutting blade, but if you force the cut, the saw can get a little jumpy. Also, if your saw has a blade oscillating feature, you have to turn that off.
c
T101BR
AZ in Colorado Springs
Score with a sharp utility knife and cut on the waste side of the line. If you need to use the off cut piece, score a second line leaving enough room for the blade and steer carefully as you cut. Smaller teeth also help, but scoring is the key, In my experience.
John Pappas
Bosch make an "Xtra-clean" blade, T308B. The package claims "Clean cuts, top and bottom". I just made a couple of short straight cuts in 3/4 inch oak ply and got clean cuts, top and bottom. On some packages, Bosch just says clean cut.... these are "Xtra-clean".
c a gernentz
thanks guys, I'll look for the blades tomorrow when I pick up the plywood at Menards. I will do some experimenting to see what works, thought maybe stoning outside edges to ease tearout but better blades may make a big difference. Oh for days when veneer was bout 1/16" tells you how old I am. Thanks again
Like some others, I really like the Bosch hollow ground blades. I haven't tried the reverse cut blades but I'll get some. I've had very clean cuts from others, far cleaner than some other brands.
