What Finishes Can Be Sprayed?
Stuart Johnson
The only finish I've sprayed is lacquer. What other finishes spray well and do they take any special thinning?
Re: What Finishes Can Be Sprayed?
I spray conversion varnish and thin as needed to get good flow out (0 to 25% xylene or toluene depending on temperature).
Shellac
Oil paint thin about 25 % with mineral spirits or naptha depending on temperature to get good atomization
DeVilbiss JGA gun #30 cap
Depends on your sprayer or gun
Dick Coers
but also latex paint, and latex enamel. Use distilled water or commercial additive. All water based versions of lacquer and harder finishes. Of course dyes and stains can be sprayed. Also polyurethane, but hard to get the correct amount sprayed on vertical surfaces without runs. Mineral spirits or naphtha for thinner. Then there are the exotic finishes of polyesters and post catalyzed commercial finishes.
Re: Depends on your sprayer or gun
Stuart Johnson
So you can spray polyurethane if it is thinned enough for the gun used? All the can say brush or wipe on.
How does the conversion varnish handle heat and humidity (right now it's 96 and 41% humidity)? Is this a Home Depot type product or will Sherwin Williams carry it?
don stephan
Your spray gun manufacturer and/or distributor should be able to offer helpful input. With information on the type of gun, needle/nozzle (n/n) size, compressor size, and perhaps a bit more Homestead Finishing Products likely can advise if any of the finishes they sell should give good results. I wouldn't look for help in a big box store because of the specialized technical nature of your question.
Conversion varnish is a professional product
Dick Coers
Pro stores only, they couldn't trust the general public to take proper health precautions. Most use an acid catalyst, so proper breathing protection is paramount! Sherwin-Williams used to only sell it in 5 gallon pails just for that same reason, no idea if that is still the rule.
Spraying polyurethane is certainly possible, but as I mentioned, it's not easy on the vertical. You'll also feel it on the hair of your arms. It stays wet in the air and settles on everything, still wet.
spraying varnish
If you look in the Gallery about every chest of drawers I have shown there is sprayed with varnish. It doesn't matter what kind of varnish, it all sprays the same. I thin it about 25% with mineral spirits or naptha depending on temperature. On a warm day it is dust free in 30 min or less; hard enough to handle in 4 hours.
I have not had any problem spraying it on anything I built.
If you happen to be in E. TN. I have some conversion varnish for sale that I bought from a shop going out of business.
Walt
You can spray shellac also. A coat of 1# cut of dewaxed shellac (Sealcoat cut 1:1 with alcohol) under paints like acrylic enamel work well in my limited experience. Spray the shellac, sand after a few minutes for a hard smooth surface. Then spray paint. I have a 2 stage HVLP so not real powerful but diluting with a mixture of floetrol and distilled water seems to work. There are also sprayable water based tinted lacquers. Some say those spray better with HVLP setups than 'latex paint'. I've only sprayed diluted paint.
I have successfully sprayed Lacquer, Varnish, Stain, Shellac, Latex paint, Minwax Poly (thinned about 50%) - in other words just about any finish can be sprayed that can be brushed. When I sprayed the Minwax poly. I used various thinners, including Acetone, Naphtha, Turpentine, dependent on the temperature and how fast I wanted the surface to dry, in cooler temperatures I use a fast solvent like Acetone or Naphtha, in high temperatures they can be too fast and not allow flow out, then I go the the slower solvents or a combination of solvents. Yep you can use almost all petroleum solvents with an oil based poly in just about any ratio you wish. The 50% mix does leave a thinner film so you will have to apply more coats.
I have older Binks guns so can get tips from the local Napa store. You can experiment with scrap, I use old cardboard boxes to find the tip size and solvent ratio's I want for good atomization, then scrap wood to see flow-out.
question
you spray latex paint with a "traditional" Binks gun? I presumed it was nto possible and never tried it. Provide details please.
Varnish of any kind does not require thinning as much as 50% with a traditional gun and a #30 cap. I use about 1 part solvent and 3 parts varnish.
BTW, those that avoid polyurethane varnish because you have been told it has a "plastic look" can get any look they want by spraying thinned varnish of any kind. Sufficiently thinned, a flat urethane varnish can look like an oiled finish at one extreme or French Polished at the other. The plastic look comes from too heavy a coating. Given that the material is formulated too thick to meet EPA requirements, it is easy to apply it too thick unless it is thinned.
