Continuous arm settee:Final-milk paint finish
Jack Guzman from Maine
I'm done with the final step of finishing on the continuous arm settee that I previously posted about. It is a multi-step process that I took pictures of at various stages. In this thread I will post some of these pictures and explain the process as I do it. This whole process is covered in a video by Curtis Buchanan on building a combback windsor.
The first thing I did was to go over the whole chair smoothing things out.Looking for rough spots,filling small holes(using water based filler)and just making sure it was ready for finish.
I start by mixing up a batch of barn red milk paint. There are two brands that I know of. I use "Genuine Antique milk paint". The other one is called "Real Milk Paint"I have heard that the other is harder to rub out but I don't know. Peter Galbert covers this subject in his blog."Peter Galberts Chair Notes"
I start with a mix of two parts powder to three parts warm water.I whip this up with an old style hand operated egg beater.Then I set the mix aside for 30 minutes. At this point the mix has about an inch of foam on top.
I remove the foam and then stir the residue on the bottom into the mix gently and then pour it through a fine strainer. Some use cheese cloth but I find it too messy. It seems like you are wasting alot of paint but the stuff that's lost would just mess up your paint job.
I apply the paint with a 1 1/2" sash brush designed for latex paints.
More to come---Jack
Re: Continuous arm settee:Final-milk paint finish
Milk Paint
I always start with the underside of the chair. I dip the tip of the brush in the paint and scrape off excess paint. I brush it on quickly. Try not to go over spots that have started to dry. Milk paint has different properties from latex paint. I would recommend practicing before painting a finished product. You need to get used to how it acts.
Some pictures of the first coat done.
After the first coat dries I like to go over all surfaces with an abrasive pad to remove raised fibers and rough spots. I go over it very lightly.
When I'm happy with the surface I apply two more coats of red paint. Letting each coat dry at least 6 hours before the next.
Now it's time for the black wash coat. I want this coat to go on thin so the red can still be seen underneath. I mix one part powder for two parts water for a start and thin more if needed. The mixing process is the same as for the red.
You need to be extra careful when applying the black. The wet paint will start to soften the coat under it and if you drag the brush through it after it has sat for awhile you will start to drag the undercoat. So be quick and careful. It's easy once you get the feel for it.
The first black coat.
second black coat (notice I highlighted the red in the grooves)
After the first black coat has dried you want to add one more coat . At this point I usually thin the paint a little more.
Remember you want the red to show through somewhat when you rub the finish. If you get the black too thick it takes alot of rubbing.
That is it for the paint. In the next post I will get to the rubbing out and final finish.---Jack
Re: Milk Paint
That looks like a lot of work. I think I would try spraying the paint.
Re: Milk Paint
It is alot of work. The hardest part is the rubbing out. I don't think milk paint would spray very well. It is some strange stuff.---Jack
Milk Paint
When the last coat of paint has fully dried I start to rub the surface. I use a maroon abrasive pad or Mirka fine abrasive pad.
You can see the change after rubbing in the two pictures.
The surface is a dull gray when I start. As I rub, the surface starts to get a gloss to it. Once I have rubbed every surface with the pads I switch to 000 steel wool. The steel wool will bring out the red and show hints of the final finish.
After rubbing out
Once I'm satisfied I can't improve the finish any more with rubbing I start the final finish.
I mix one part boiled linseed oil ,one part spar varnish and one part mineral spirits. I wipe this mixture on and after waiting about 15 minutes I wipe it off. You want to get the excess off before the surface gets too sticky. I let this dry 24 hours and do it again a total of three times.
And that is all of it. Wax if you like but at this point the piece is done.
thanks for looking and feel free to comment or ask questions.---Jack
Re: Milk Paint
Ron in Sterling, CT
Jack,
That is an absolutely stunning piece. Thanks so much for sharing the journey with us. It was a lot of work, but the end result makes it all worthwhile. It looks almost to nice to sit on. By the way, what did you end up with as spar varnish in your final recipe?
Ron
Milk paint comment
I have used it. I quickly learned to hate it. General Finishes had a product , I think called Country Colors. It looked like milk paint after it dried but it went on so much easier. If I was making things to sell and not interested in Period Correct I would be developing a finish that would be less labor to deal with. I got the impression for Curtis that finishing took longer than making....but he makes incredibly fast.
Re: Agree with Ron
Hank Knight
Jack, I agree with Ron, that is a beautiful piece! Thanks for posting your build. I enjoyed it. I put a similar finish on a hunt board I built several years ago. It was a lot of work, but the end result was very attractive and well worth the effort.
That looks great! (the piece and the paint)
I never tried milk paint until last week. Clay Foster introduced a woodturning class to milk paint and some of the ways he uses it. He often applies multiple coats and sands through them either one at a time or all at once to reveal colors underneath.
Clay said he has tried a variety and his favorite is "Genuine Old Fashioned" milk paint.
Don Orr
Beautiful work in all aspects Jack. Thanks for taking us through your process.
Re: Milk Paint
GolfSteve in Calgary
Lovely, Jack. Making one of these is on my to do list....
I painted some kitchen chairs several years ago using exactly the same process, including the final oil coats. I found that washing the chairs leaves black residue on the wash cloth - even now, years after painting. Aggressive washing will remove paint, excessively "distressing" my antique looking chairs.
Do you find the same thing?
One nice thing about the milk paint is that is does not have that "gummy" feel that latex paint has. I like it, but my impression is that milk paint is not particularly durable to stand up to repeated washing.
Re: Final-milk paint finish
Well done, Jack. I can see why you need the durable varnish topcoat.
Enjoy your piece
Re: Milk Paint
I found a couple quarts at a different hardware store. If it is discontinued to the general public I will have to find it in marine places. Thank you---Jack
Re: Milk Paint
I haven't had a chance to experience what you say. I haven't done this long enough,but I will check that out.---Jack
Thank you Mark
Re: Milk paint comment
Bill it doesn't take that long. It is alot of drying time however. It isn't about being period correct.I know no other way to achieve that look. To be period correct I would be using lead paint.---Jack
Re: Agree with Ron
Thank you---Jack
Thanks. I looked for information on settee building before starting this and there was very little to see. That is why I decided to share this build.---Jack
Re: Milk Paint
Keith Newton
That is very nice Jack. I like it a lot. Are you planning to make more of them?
Re: Milk Paint
Every chair I build,I make patterns and jigs for. I can build a replica for any one of them. If someone asks for it ,yes I will build another. My wife claimed this one so I may at some point make another to have on display.
For now I have other chairs to build. Thanks---Jack
