How can I load a cherry log onto a trailer
A cherry came down in the wind, about 18" x 10' log in it. I can back a trailer to the log. I have a 10' trailer but it has sides that are not removable. I have cant hooks. I have a 1/2 ton chain fall and light duty comealongs. I have a farm jack that can lift about 3'. I have a helper. What I don't have is an idea for rotating the log 90 degrees and levitating it into the trailer.
Re: How can I load a cherry log onto a trailer
Kneale Brownson
Tripod and Chain Fall?
Kneale Brownson
Or jack, block, jack some more?
I thought you had a "farm" and a tractor.
It's called parbuckling, moving by rolling
Dick Coers
Used to parbuckle the big logs onto my mill. I'd park my van on the back side of the mill, wrap a chain around the log, hook up the come-a-long to the trailer ball, and roll it up. You can roll up just one end of the log onto the trailer by rolling at an angle if necessary, or just block up over the tires and roll it on from the side. A second method is to use a pivoting frame and a winch. It lifts and pulls in little "bites".
Ralph Lipeles
Use a chain and your car/truck to pull the log into the position you want it in. I just had to do that with a tree that came down blocking part of my driveway and sticking out 8' into the road.
I've done this...
Bill, I've loaded many logs onto both a flat-bed truck and a trailer by myself using a chain and a couple of ramps. I learned this trick years ago from a logging forum and it has always worked for me.
What you do is put the trailer next to the log and place a couple of ramps. I have a couple of 10' i-beams I use but timbers should work. Might need some blocks to clear the wheel wells depending on the log and/or the trailer. Sometimes I put the ramps on the wheel wells if the log is not too heavy or long. (My trailers are pretty stout.)
Pry up the log or scratch the ground if needed to get a couple of inches clearance in the middle. Fasten a chain (a stout rope should work) to the middle of the log and wind the chain multiple turns around the log in the direction so the free end of the chain comes off the top of the log towards the trailer. Pull the chain from the far side of the log and the log will roll up the ramps.
Use blocking/chocks as needed to control the log movement when it hits the deck. I do use pry bars and/or cant hooks to keep the log straight if needed.
I usually pull with a car, truck, or tractor but even a 4-wheeler or the muscles of several people might work. (You can estimate the log weight and calculate the pulling force needed from the radius of the log and angle of the ramps. You can also calculate the number of wraps of chain/rope needed to get it up the ramp.)
I have also used a come-along (I have a real one, not a piece of sheet metal junk.) If there is no room on the other side of the trailer for a vehicle to pull, you might fasten a snatch block to a tree or something and pull a rope at 90 degrees from the direction of rolling.
The other way I use is haul the tractor or bobcat to the log on the trailer, load and move the log, then drive back to get the tractor. This is not a good method if you don't have a tractor or bobcat or the log is far away!
Be careful, of course.
Re: I've done this...
I had not considered the ramp. It would be no problem rolling the log up such a ramp with a cant hook. I have 2- 12" oak 4 x 6's that should do. But how to fasten ramps to the side of the trailer? I suppose I could haul some cement blocks to the site and set them next to the trailer, but that is a lot of block to get a 30" rise. If the trailer didn't have permanent sides it would be easy.
I wonder if it would work to raise one end of the log and just back the trailer under the raised end and push it on?
Re: Tripod and Chain Fall?
Farm is 50 miles from the forest with the log. This small log is not worth a lot of effort, certainly not enough to haul a tractor there. I don't have a trailer that will haul a tractor.
Sounds like you plan to move the log elsewhere for it to be sawn later? Otherwise, would someone with a portable saw mill be an option and cut it on site?
T.
If you do a one end lift
Gary Smyth
I urge you to check the trailer tire pressures beforehand and also the condition of the tongue to the truck. Recent misadventure involving bobcat loader, dirt, and trailer, popped the tire from the rim with the weight of what I thought was a relatively small 1/2 cu yard of fill that was placed behind the wheel well. All it took was a left hand turn from dirt to pavement to exit and poof. Few things more stressful than a loaded trailer in a travel lane with the tire off the rim far away from home. In addition, the weld on the tongue cracked probably when the load was dropped. Better to check in advance.
How sturdy is your trailer?
Henry Higginbotham
And how high are the non-removable sides? John's suggestions work well if the trailer is up to the task.
About five years ago, I helped get some cedar out of an old country cemetery. Loading the trailer was the easy part--someone had already dropped the trees and taken the easy pickings, leaving the bigger logs in the middle of hundreds of grave sites. Most had to be ripped in half with a chain saw and then snaked out with cant hooks and rollers (made from tree limbs).
Loading the trailer was mostly as John described. The ramps have a steel plate bolted to the end, with a hook. (Angle iron? I don't remember.) I suppose, to take some strain off the sides, the hook could extend all the way down to the deck.
Too bad elections aren't closer. Coroplast political signs make good sliders. With enough of them, you can slide logs on from the end. And make the roadway look better in the bargain.
My trailers don't have sides.
The wood web calculator indicates your log probably weighs over 900 lbs.
http://www.woodweb.com/cgi-bin/calculators/calc.pl?calculator=log_weight
Lifting one end and sliding might work ok. Be sure the weight on the back doesn't lift up the back of a light pickup. Before I got the bobcat for unloading I'd pull the log off the trailer with my jeep using 25" skidding tongs. The bottom logs almost always got hung up on the trailer.
An old way to lift and move one end of a heavy thing is make a tall A-frame and pull the apex with a rope to use take advantage of the mechanical advantage. Use a second belay rope from the rear to control lowering the weight. I couldn't find a picture but this article has a description:
http://www.firehouse.com/article/10540516/lifting-heavy-objects-timber-a-frame-gantry-part-i
http://www.firehouse.com/article/10535026/lifting-heavy-objects-timber-a-frame-gantry-part-ii
http://www.firehouse.com/article/10528397/lifting-heavy-objects-timber-a-frame-gantry-part-iii
A simple a-frame could lift one end onto the trailer (in stages if necessary) then lift the other end to horizontal. Perhaps pull it onto the trailer with a comealong.
Of course with a load use a sturdy trailer with good tires and drive slowly. My big trailers have dual axles and electric brakes. I've hauled over 8000 lbs on the 18' gooseneck. I pull with a 3/4 ton diesel pickup.
Forgot to mention that in a pinch
Gary Smyth
a ladder can be used as your ramps. The rungs can provide tie off points and stops. If the log is indeed 900 lbs. you probably not want to to use a ladder as mine, for example, is 300 lb. Even for a short haul a heavy log could endanger the rails, but an extension ladder can provide four ramp surfaces and a reduced load. If it can take the stress it could save you save you building something special.
If I had your gear, I'd do this:
Grant in Iowa
Firstly, you didn't say if you had ramps for your trailer, but there are easier ways to load the log if you do. I will assume you don't. Your target log weighs about 920 lbs or so. It is quite doable to load this using the items you have on hand.
Assuming you don't have ramps:
1. Since you have a chain fall, the goal will be to simply get one end of the log on to the rear lip of the trailer. The chain fall will take it from there.
2. From the remainder of the tree, cut several logs to serve as fulcrums (we'll call them fulcrum logs). Make them in varying sizes. Ideally, you will have pieces ranging in diameter from about 6" up to a little over half the height of your trailer. Make them long enough to provide some measure of safety should the target log decide to roll, I'd suggest 2 or 3 feet long.
3. using a chainsaw (hopefully a fair assumption), cut a long wedge to serve as a ramp to allow the log to be Peavey'd up on to the smaller log that will serve as a fulcrum. Arrange the fulcrum log so it is centered on the log to be harvested. You want to end up with the log to be harvested laying atop the fulcrum log like a seesaw. The hard part is now done. Discard your homemade ramp, or better yet use the wedged end for wedging the target log to prevent it from rolling as we do the next procedure.
4. Now, using your helper, "teeter" the harvest log and insert the next larger size fulcrum log as close to the first fulcrum log as possible. Push by hand the end of the target log until it is balanced atop this new fulcrum log. Easy cheesy. Have friend hold things in place while you get the next fulcrum log ready.
5. Teeter the harvest log to allow the next fulcrum log to be inserted. If needed, adjust balance by again pushing the target log lengthwise until it balances atop the newest fulcrum log. Keep doing this until one end of the target log will clear the lip of your trailer. Either block the log in position, or get the aid of your helper while the trailer is backed beneath. Once the log is resting on the rear lip of your trailer, have your helper get out of the way and continue backing the trailer under the log as far as it will go. At some point it will slip (or , if you plan well, it can be pushed on the trailer using another tree or the stump as something to push against.)
6. Finish the job with your chain fall by using it as a winch to move the log forward on the trailer.
I have attached a crude stick-man drawing since a picture is worth a thousand words. let me know if you need a different file type than pdf...
Regards,
Grant in Iowa
Rotating the log 90 degrees:
Grant in Iowa
I forgot to mention how to rotate the log 90 degrees:
Get the log atop another at a 90 degree angle so it more or less balances. Use the wedge I mentioned in my previous email as a ramp. Then it is easy to rotate the top log since the friction is now minimal. You can turn it up to 90 degrees, at which point it will fall back off of the fulcrum log, but not a huge deal since you have the wedge technology and peaveys.
I have used this and the previously described methods extensively before I got the machinery to do things with less effort. Indeed, sometimes I find myself working harder to get all of the equipment to the site than I would if I just did things by the old manual methods such as parbuckling and using fulcrums to lift logs.
Let us know how it works out.
Regards,
Grant in Iowa
That gave me an idea
I have what I call a farm jack. It can lift large weights up to 3'. I'll see if I can short cut the see saw by putting a chain around one end and simply jacking it up in the air as far as I can as I roll the pivot to the middle. A small vee chopped in the pivot log will keep the log from rolling.
I think I can either skid or roll the log into position for raising it.
The decision to be made is whether it is worth the effort. It will be a lot easier to make it into firewood.
Wondering how to keep the jack stable
Grant in Iowa
Bill,
I am familiar with a farm jack, and if it is the one legged version I know so well, I have to wonder how you could keep the log from wanting to tip over as it is raised. You may have more experience in that regard than I, but it seems it might be tippy, especially on the forest floor.
My approach made the assumption that there'd be lots of firewood laying around as there usually is, so I wasn't thinking cutting the fulcrum logs would be really wasted time since the tree top needs cut up anyway.
Regards,
Grant in Iowa
Re: Wondering how to keep the jack stable
I had several pine trees taken down in my yard. The logs were much bigger than what you describe. I bought two hand trucks form Harbor freight and took the wheels and axles off them and made a cradle for them. Levered the logs up enough to get the cradle under them and rolled them down the hill into my driveway. A bit of a wild ride but it worked. After I finished I reassembled the hand trucks and still have them.
Years ago I hired several companies to move houses for me. (Moved eighteen) I was astonished at how simple and crude the process was. They levered steel beams up under the houses, lifting the beams a few inches at a time and placing "cribbing" under them. Once the beams were in place they used four ten ton (?) jacks to lift the beams and house off the foundation. The point is that with little more equipment than you have they were lifting houses.
A third guy might make it easier, but you can lever up one end higher and higher until you can get a block / pivot point under the center to rotate the log ninety degrees. Then you lift the end high enough to get the trailer under it. Then the come along will drag it into the trailer. You will need ten or fifteen blocks of cribbing maybe 4 x 6 by 24" Cinder blocks might help but tend to break in this application.
The easiest thing I've found,
Keith Newton
Is to cut one of your larger limbs at a long low angle to use as a ramp. Leave about 18" of full round past the heel.
Put the point perpendicular near the middle. Wrap a choker chain around the log, with the pulling end over the top, so when you use your truck to pull, it will roll up the ramp, and be nearly balanced on the full round like a teeter totter.
Now back the trailer under the high end, until you are against the fulcrum/ now roller. I keep some short pieces of 2" PVC sch40 for rollers in the trailer, to ease the drag friction. I used to start pulling with a come along here, but the hardest resistance came from the back corner of the trailer bed. So next, I found that after I was pulling from the front, if I drove the truck forward half the distance of the overhang out the back, the roller log would be half way out, and would roll along the ground holding it up until it was fully in the trailer.
I have to agree
Your method makes a lot of sense. But with this log it will be easy to simply roll the log onto the fulcrum with a cant hook. I wonder if I put part of a sheet of plywood between log and trailer it would skid easier over the back edge of the trailer"
Re: I have to agree
Keith Newton
Yes, that will work. I'm usually working with much larger logs, where everything I can do makes a big difference in amount of energy spent.
Log weight/blocks/skidding *LINK*
Tom Dunlap
18"x10'=790#
Lots of good suggestions but i haven't read them all.
I took some spruce logs to the mill and had them cut into a couple of rectangular cants. If memory serves me they were 10x12 or so. Then I chunked them down into 4', 3' & 2' pairs. It took a couple of trees but I ended up with at least four of each length.
Since they were rectangular I could get the cribbing up high without using a bunch of 2x material.
After they dried the cants were quite light, even the 4'ers
I'm not sure why you need to rotate the log unless it is to orient it to load lengthwise on the trailer. A log that size should skid around pretty easy with cant hooks and a hoist. Chock one end and pull the other with cant hooks assisting. Use your truck to anchor or pull. If you can drag it with your truck then skid it under a stout tree and use your hoist to lift if then back the trailer underneath.
I have lots of strong ropes and rigging blocks but you might not. If you do...try this...use a strong sling to choke the small end of the log. Attach a block to the sling. Drop the trailer and chock the wheels. Anchor one end of the rope to the tongue of the trailer. Run the rope through the block then back to anchor on your truck. Around a tow point...NOT around the ball! Gently pull ahead and the log will skid onto the trailer. Have a cant hook handler there to coax the log on...but stand clear the log can roll on a knob.
Take pics and share...or we won't believe that you didn't find a levitator to load it up!
Green log weight chart
