Car guy question...99 Mazda Pickup heater core???
I have a 99 Mazda B3000 pickup. 6 cylinder. Sometimes I smell antifreeze in the cab. As far as I know there is no significant loss of coolant and none leaking into the cab. Same truck as a Ford Ranger.
I am assuming the heater core has gone bad. I looked up changing the core on YouTube and its a much bigger job than I imagined. Looks like you remove the dash and steering column. (What?)
What should I be checking? What else could it be? Is there a magic solution? Some kind of Stop Leak? Or should I just ignore it until the problem becomes obvious? Or sell the truck?
Re: Car guy question...99 Mazda Pickup heater core???
Mark Nowicki
Don't assume it is the heater core.
It could be a leaking head gasket, with the coolant leaking out on the exhaust manifold and the fumes getting into the cabin air by the vent under the windshield.
You should not have any coolant leakage.
Before you start throwing parts at the car, do a leak down test and pressure test the cooling system.
You will need to buy or make a tester or pay to get it tested
https://www.youtube.com/watch?v=WgrfT0LFMhc
If it is a head gasket you have a decision to make.
I just finished the head gasket repair on my 2010 Dodge Journey.
The parts, special tools, head machining, timing belt, water pump etc, etc came to about $1,200.00, took six months.
Mark
Tom Dunlap
After having to deal with heater cores over time I'm convinced that the car comes down the assembly line as a frame and the first thing that's installed is the heater core and shroud. Then the rest of the vehicle is built around that!!!
There are sniffers that you can buy that might isolate the leak if it is the heater core. You might check with AutoZone or some other store that has a loaner program.
There may be a workaround too. Find a Mazda/Ford user group.
I have an Astro van and I've learned a lot of shortcuts from them.
Tom
Kneale Brownson
Pinhole leak in some other part of system?
Kneale Brownson
Hoses and reservoirs can develop tiny leaks that only open when hot and pressurized.
You sure you're not smelling the car ahead of you?
Grant in Iowa
Next time you smell it, turn your heater/ air conditioner to "Recirculate". If you still smell it after a time, it is likely the heater core, unless you have air coming in through the firewall (shouldn't).
If you only smell it with fresh air on, then it is a leak under the hood.
I stopped by my mechanics shop one day a long time ago and they had this Volvo wagon in for some work. They had the seats out, dash out, the carpeting out of the front, the center console out, and a bunch of trim pieces above the dash out. I asked what happened to this thing? He said "heater core". He went on to say that "Volvo puts the heater core on that model about centered behind the dash on the firewall, behind all the heater stuff and electronic stuff and you have something like five hours to get to it and six hours to put it back together". The extra hour putting it back together is to ensure all of the pieces are aligned right and the little push clips get replaced so there are no rattles, etc. He did say they are great cars if you are the first owner and trade them off before they need major servicing.
I now base my car buying decisions mostly on the advice of my mechanic. Since then, I have not been stranded, and have been pleasantly surprised by the lower bills. These guys know what fails, and who builds cars that are easier to work on when they do.
FWIW,
Grant in Iowa
