ADVERTISE HERE - FREE TRIAL
Installing a pre-hung door
AZ in Colorado Springs
A friend needs an additional bedroom in his house, so he hasked to wall off a part of an open loft area. Now I need to hang a 32" pre-hung door. Any tips?
Re: Installing a pre-hung door
Re: Installing a pre-hung door *LINK*
Tom Dunlap
Seems like an easy procedure:
Door hanging
Jack Guzman from Maine
Sounds like he's overcomplicating things. I have installed many doors in my job as a carpenter. I remove the door by pulling the hinge pins.Plumb the hinge side and secure it with a screw through each hinge into the frame using shims to fill the gap. Rehang the door and adjust the rest of the frame to fit.Simple stuff.---Jack
I have hung hundreds of prehung doors. Its either very easy, or NOT.
Easy is if the jamb is plub and true on all three axis. If the floor and head jamb are level that's a good start. If the inside face of the hinge jamb is close to plumb, that's a good start. And if the edge of the jacks or trimmers on BOTH sides of the opening are plumb and in a plane, that's a good start. If the opening is not in a plane and plumb you are off to a rocky start.
Are you using a split jamb?
Assuming the opening in well framed and in a plane and plumb, Separate the split jamb and sit the hinge side with door in it in the opening. Raise the hinge side off the floor to accommodate the thickness of the floor covering. About a half inch for carpet or none if the finished floor is in place. If the floor is level the strike side will be the same height. If the floor is not level you may have to cut off the hinge side to allow the strike side to sit on the floor if its the finished floor. If its carpet, this is not critical, the variance will be buried.
With the hinge jamb in the opening check it for plumb by placing the level on the hinge knuckles. It helps to have a six foot level so you can touch all three or at least the top and bottom ones. You can tape a shorter level to a nice straight stick to temporarily make it longer. It needs to be plumb in the plane of the wall and at ninety degree to the wall. Shift the jamb left to right until the door is plumb in the opening. Nail the facing near the hinges. Lightly shim the hinges. Close the door in the opening and adjust the rest of the frame to fit the door and nail the facing in place around the door. Check to see if the door closes nicely against the stop. The frame at this point is pretty spongy, so you can spring it into and out of the opening to adjust its fit against the door. You will need to have shims between it and the framed opening so you can nail through the split jam, through the shims, into the framing to hold the alignment. Once the door is Swinging and closing nicely You nail thought the shims. Also shim at the strike. Insert the other side of the split jamb. Nail the facing on that side. Squeeze the two sides together and nail through the stop to pin both sides.
Think of the hinge pins as a long straight rood that passes through all the hinges and perfectly straight. If it is plumb and straight, the door will swing smoothly. If the hinges don't line up the door will be hinge bound and not swing well. If it is out of plumb the door will swing on its own. That's why you plmb it in two directions at ninety degrees to each other.
I start with a bundle of shims I cut down to about three inches long. By pairing them thick side to thin side, you can slide them in and out to change the thickness. And you can use them to correct for a twisted jamb. The flat shims will be handy if the jamb is square in the opening.
Bill Howatt
I just finished installing one and I'm not a pro but have done a few doors. The truer the rough opening is the easier the hanging.
In the past I've used the shim method but this time the guy at HD pointed out a kit of 6 thin metal "clips" that take the place of shimming. I decided to try it and it worked quite well. 3 of them screw on the hinge side and are aligned with a plumb line you scribe on the wall near the opening. They hold the jamb to wall with long screws in slots so you can adjust the position. There are 3 that go on the other side. No need for shimming just adjust the position of the clips/jamb for proper alignment before driving holding screws tight into the stud through the typically drywall.
They don't do anything you can't do with shims but I'd say it is a bit easier doing adjustments.
Bill
That was interesting. I have never seen a Plastpro door or Gary Katz. I am still skeptical of composite jambs. How will they hold up in sunlight? I like the rot resistance, but still skeptical of the UV resistance. The flexibility still bothers me a little, also. The few that I have seen and installed, (not this brand) had very little nail or screw holding ability. The nails just pulled through. Ended up using siding nails to get enough head on them to hold much of anything.
What does he do with those exposed screws in the jamb? 1 to 4? Buttons? Plugs? I wonder about the upper hinge screw. The entire weight of the door hangs from that screw. Need to be sure the trimmer or jack stud is very secure.
I think my old fuddy duddy is showing. Do they sell split cambs in other parts of the country?
Mark Nowicki
Gary Katz is well known in the construction trades. He moderates the Finish Carpentry forum on jlconline.com and he also has an online magazine, thisiscarpentry.com.
I respect his accomplishments and his skills, and I have made a good living using his methods .
He is also an unapologetic shill for his sponsors, which allows him provide a lot of valuable information freely.
George Koch
Mark, Does Gary Katz have a video showing one man installing a solid door(no large cutout opening) in a solid wall(not one you can walk around) to fasten the jamb without opening the door? And maybe that side being a 2' x 4' closet with no lighting in it!
Barry, We use to use split jambs in the 1970s, but they were replaced about 1985 by solid jambs, cased on the hinge side, which made for a better and more solid installation. George
I noticed he was shill for his products. That does not mean he is not correct in his methods and does not mean his products are in any way inferior. There is a lot to be learned.
I still wonder about the longevity of composite jambs. I live near Richmond, VA, an old city with historic roots. I am constantly called upon to inspect older swellings. I have formed the opinion that while I see hundred year old wooden windows and doors, no one will ever see hundred year old plastic windows or doors.
I commonly see ten or fifteen year old modern door jambs that have rotted out. It's clear we need superior material to use in those places. We no longer have old growth rot resistant timber for that application. Perhaps composite material is the answer. The early generations of composites were not good. I often see PVC trim that has turned orange and failed. The entire first generation of Trex was recalled. Several manufacturers of siding produced seriously flawed products. Hopefully the manufacturers have learned. It appears to me they are doing the Beta testing on the public.
Mark Nowicki
I don't know if he does, but here is how I do it,
Method #1: shim in place, even the gap between door and frame, foam in place (not the boy scout product with a plastic straw, Hilti gun and Hilti foam)
Method #2: Remove door from frame , plumb and secure hinge side, rehung door,
adjust frame. I use an airbag (Winbag) to raise the door to proper height. It easily raises a 75 lb door.
Mark Nowicki
Barry, last year, my brother bought a new apartment in Europe.
Comparing the quality and workmanship of doors in Europe, I can say without hesitation, that all doors in North America are garbage.
Gary can shill all he wants, but in the end, you can't polish a turd.
Thanks for all the comments
I got to the door today. Took me about an hour for the install. I appreciate all the advice. The door closes smoothly and stays closed without a knob installed yet so I think I got it all plumb and square.
