Re: Generator Quiet Box Design Considerations *LINK*
Gary Smyth
Up front I don’t have an answer. Long ago I did some academic work on audio studios.
What you hope to achieve is very difficult given small budget, portability, and effectiveness.
There are a myriad of factors you need to consider but the first is the sound pressure level you have now with the generator at some set distance without deadening. Then you need to know the level you wish to achieve. Sound reduction levels are not a linear progression. Decibels are a logarithmic progression. There are charts available (one is linked below) that provide typical sound levels to assist you in determining how much would be acceptable to you or the neighbors
1. Mass is the easiest method to reduce sound (but not for your application).
2. Sealing the enclosure is a close second.
3. Isolation (springs, vibration isolators) of the source within a space helps prevent transfer of sound
4. There are peak levels and there are sustained levels. A peak example would be a gunshot. Sustained levels examples would be that of extended time ambient noise in an empty room.
5. You need to determine what level is acceptable at a set distance away from your enclosure.
That said, there are several things that you can experiment with that don’t cost a bundle, weigh a ton, and are relatively portable, and effective -- fiberglass batting, homosote, covered baffles, non-parallel surfaces, commercial landscaping, car, or tractor mufflers, acoustic tile, or panels of perforated metal.
Obviously, if you seal the area you will get better sound reduction, but the generators can’t operate without air. If you provide for ventilation you give the noise a pathway to the outside. All depends on what sound level is acceptable. Don’t forget heat buildup. Don't forget easy access and fuel replenishment.
No answers but perhaps a starting point
Environmental Noise
Weakest sound heard 0dB
Whisper Quiet Library at 6' 30dB
Normal conversation at 3' 60-65dB
Telephone dial tone 80dB
City Traffic (inside car) 85dB
Train whistle at 500', Truck Traffic 90dB
Jackhammer at 50' 95dB
Subway train at 200' 95dB
Level at which sustained exposure may result in hearing loss 90 - 95dB
Hand Drill 98dB
Power mower at 3' 107dB
Snowmobile, Motorcycle 100dB
Power saw at 3' 110dB
Sandblasting, Loud Rock Concert 115dB
Pain begins 125dB
Pneumatic riveter at 4' 125dB
Even short term exposure can cause permanent damage - Loudest recommended exposure WITH hearing protection 140dB
Jet engine at 100' 140dB
12 Gauge Shotgun Blast 165dB
http://www.gcaudio.com/resources/howtos/loudness.html
