A couple of painted Entryway pieces
Alan Young
Alan Young
Just finished the first two of four pieces for a local client. All pieces are/will be painted white. The client had the cushions and pillows made for each piece
Entry Hall Bench
Entryway Hall Tree
Re: A couple of painted Entryway pieces
Those look great. Is the tree in two ore more pieces? Does not look like it would tip up in a single piece.
Alan Young
Alan Young
The Hall Tree was built in three sections-Base
Mid section on Base
Top on Mid section
Not room enough to stack all three in my shop
I moved them outside where they were glued and screwed together in one monolithic form- Then painted. The finished pieces was quite heavy but my son an I were able get it in a rented U-Haul cargo Van-we drove it about 12 miles from my shop/house to the clients home- These drawings sort of show the entry configuration-. The end location shows a tight fit to the ceiling- but just inside the door is a path aprox 4 feet wide will a higher ceiling-We could bring the piece in the door and had enough open space to tip it up then slide it under the ceiling into it's location
Alan Young
How Bizzare!
Alan Young
I posted pics from my computer of my project yet I see Pictures from Bill Tindall's recent post on case base construction---I have no clue what happened???
Alan Young
Re: How Bizzare!-Let's Try again
Alan Young
Here are the sections as I built them-By the time they were complete there wasn't enough room in my shop to fully assemble them. I moved them out side-where I glued and screwed them together
After the monolithic structure was painted- we transported it in a UHAUL cargo van to the clients house...These drawings sort of show the entry configuration-. The Hall tree's location shows a tight fit to the ceiling- but just inside the door is a path aprox 4 feet wide will a higher ceiling-We could bring the piece in the door and had enough open space to tip it up then slide it under the ceiling into it's location
johannaj
johannaj
I sure am glad I'm not the only one who can put the wrong picture in a post!
Nice design.
