Chest of drawers back on the bench-sadly
So, what is this all about. Years ago when I began building chests of drawers for the family one sat in the damp garage for a few days before delivery. The drawers had been "perfectly" fit in the shop. After a few days in the damp garage the drawers were no longer perfectly fit. Having experienced that lesson I came to equilibrate furniture in the dampest place I could find before delivery. I have become confident that I can anticipate climate change and fit accordingly in the shop. Well, not always........
I spray outside and cure the piece in the garage. It has been exceptionally humid of late. When I went to load the piece for delivery after it had set in the hot and humid garage the middle drawer no longer worked smoothly and it was not apparent why.
It appears that more then one slight change led to the drawer not sliding smoothly. The side of the case had cupped a slight amount. The side was held in place by the top and bottom dovetails but not in the middle. Also the drawer had bowed slightly. The sum of these and maybe other changes led to the unacceptable drawer fit.
I hand planed the inside of the case level as well as the drawer side. The planed surfaces were recoated with shellac and rewaxed. Now all is well, but, I was unable to return the piece with the grand daughter owner to KY.
Re: Chest of drawers back on the bench-sadly
Jim Dillon
Hi Bill, don't be too hard on yourself. As, I believe you've said in the past, "stuff happens". While I don't have a lot of experience in drawer fitting, for me, later problems seem to arise when I try to get a drawer to fit too closely, i.e. the proverbial "piston-fit". Then with humidity changes, especially with what we have been experiencing this summer in the east, even after acclimating the lumber, a sticky drawer happens. I had this happen with a bathroom vanity. Your solution sounds good and hopefully you will deliver the beautiful chest at a somewhat later date. Thanks for posting "real-life" problems that occur so the rest of us (including me, for sure) can learn from! Jim
Kneale Brownson
Fate gives you reason to visit them again.
I have felt your pain
Bill,
Glad it worked out. I have had that experience. But what a lovely piece!
T.
At first glance I was horrified......
In the photo it looked like the angle across the base was smashed. At first I thought it had fallen out of of the truck or something.
Glad what had happened was not that bad. Good you were able to fix it.
Re: I have felt your pain
It's a whole lot less "painful" when it happens before delivery :) ( as I am sure you know!)
Thank you for the compliment.
