Ditto and...
Grant in Iowa
I too like this blade. Freud makes great blades that are widely available, and local resharp services can readily set up to sharpen them since they are common.
I have one of these blades, but I also have a Freud LM74M010, which is a 30 tooth blade without the red coating. Slightly better finish due to more teeth, and yet a slightly lower cost because it lacks the fancy coating.
On the red coating, I find little use for it in my shop. I seldom touch wood to the plate of the blade, as I usually work with hardwoods, not construction grade lumber. I'd rather have more teeth for my money. Further, the chrome colored blades are easier to do accurate run out measurements, since there's no paint in the way.
They both work well, and can produce a glue line surface.
One more note: If you have your saw precisely aligned and set up, endeavor to do precise work, read on. The silk screened lettering on these blades can throw off your blade run out significantly if it gets between the saw arbor flange and the blade. I take a razor blade and scrape off the lettering in the area of the arbor before using. This ensures the blade sits flat against the arbor flange on my Unisaw.
I know this sounds crazy, but the lettering is maybe .002 thick, but its location is like placing a shim in one location between your arbor flange and the blade. The issue can cause the outer surface of the blade plate to have run out up to .008 or more, since the "shim effect" is magnified at the outer edge of the blade.
Doubt me? I showed this to a Freud regional sales rep and he measured it with me using a dial indicator before removing the label and after, and he agreed that this is clearly an issue. He even said that the last thing to go on the blades in the hands off factory is the screen printing. Claimed he'd take it up with corporate. I see nothing has changed on the blades though. You'd think they'd make a change, as with .008" of run out, you can see the finish difference.
Regards,
Grant in Iowa
