Diy screen windows for screen porches.
TomD
With my parents getting into their 90s, I am adding a deck on the lake house with a screen porch, so they can enjoy time outdoors without having to climb stairs or fight the elements.
For the most part it is cold and windy up here, with relentless bugs. So heat is not the issue, in fact I will get more driving rain and snow than heat in a given year.
Seasonal folks normally build a roof held up with a few posts and wrap it with netting held in place with battens. In my case I will have to provide some system of clear windows to protect the inside from driving rain. There is no budget or access to any fancy system using extrusions etc... or full windows as nobody sells that stuff up here, even if there were the budget for it.
The best DIYable system I saw years ago involved framing stud a sheathed walls with unusually large window openings, these had frames on the outside that overlapped the window framing so that a screen could be inserted. These windows used two layers of velcro so that a vinyl window and the screen could be rolled up. It was still pretty expensive, and required equipment I own to build, but don't have here.
https://www.youtube.com/watch?v=_YIRNo0djnE
Anyone have any suggestions? I have googled extensively and don't see much that DIY has had to offer, or even This Old House, often early episodes were a little more real for people like me. The system I saw was in a cottage life episode, but old episodes don't come up.
Re: Diy screen windows for screen porches.
John Veerkamp
Check out storm windows. When I re did our screen porch a few years ago I went to Lowes and bought storm windows with screens. If you use self storing storms the windows are raised and lowered from inside. Then make your framed openings to match standard sizes.
Keith Newton
I built the Sun-room at my cabin using seven 6' x 6'8" sliding patio doors. This is in a room 14' x 21', so two on each end, and three along the long wall. That was about ten years ago, but the were only around $350 each from HD. So half can be open to let the breeze blow through, or closed when it is too cool. They are easy to install.
Many years ago I built a house with a porch. I went to the hardware/borg and measured window screens. I deciphered how the measurements of the screens related to the dimensions of the windows and then set up the openings in the porch to match the screens. A groove at the top and some stops was all it took to make it so the screens would just slip into place. It would be easy to make plexi panels that would substitute. I ride by the house occasionally and notice the "system" got lost in time.
Another thing I have done is use storm windows without any regular window, just screwed t the framing. Did that on several yard buildings. Seems to work fine. Makes cheap windows with glass and screen.
This was thirty five years ago. I don't think the "roll-up" version existed then.
PS.....
I was typing, slowly, while Keith and John were answering. I too have done several porches with patio doors. He's correct. Makes a nice porch.
Do you have any resources like Habitat for Humanity Restore? Sometimes Lowe's and Home Depot sell things people order and don't take or slightly damaged materials that you can repair and use. Hard to find a bunch of matching stuff thought. I built an entire house out of "rejects". Actually a lot of top notch stuff that was a little care worn. Actually built several of them.
Mark
My Screened in Porch at the Cottage has the screens on the outside simply held against the window by inexpensive butterfly clips.
I also had a series of Clear Vinyl windows /panels made by a local Boat Cover upholsterer.
The clear vinyl is widely used for replacement windows on Boat covers and is available in a variety of weights and thicknesses.
They are a straight forward panel hemmed and framed with velcro with two velcro strips on the top left and right sides that allow them to be rolled up and stored when not needed.
A small 1 " frame on the inside of each window has the other piece of velcro stapled to it to secure the Panels.
They are easier and lighter then managing windows, they get out of the way and allow max air flow, and also keep out the rain effectively.
On cooler nights with the vinyl windows rolled down, a few candles burning in lanterns actually lift the temperature and take out any dampness.
If you can find a Boat upholsterer I am sure they could make you some simple made to measure panels.
David Bair
Curious why you would want windows on a boat cover?
Mark
There are certain types of boat covers designed for use in Bad weather. They have zippered side windows that can be unzipped a bit to vent or zipped right up to keep the weather out. That's the clear vinyl material is what they use for these.
I guess my use of "Boat Cover" conjures up a totally enclosed storage cover , versus a running top or Cockpit cover.
TomD
Thanks for all the suggestions, I have some more things to think about. After saying no to canned solutions I am looking at Screen trim, only problem that it isn't sold up here in Canada, so I would have to border hop to get it. So I will continue with the DIY solutions and ideas a little longer.
