Good Caster Wheels
Stuart Johnson
I need to replace casters on my jointer and 14 inch bandsaw. Both are on Shop Fox bases. What are good replacement wheels. The ones I'm replacing just crumbled away.
Good Caster Wheels
Stuart Johnson
Re: Good Caster Wheels
William Duffield
An interesting question, Stuart, but all I have is anecdotal data. I also have had multiple sets of caster tires crumble away over the years. I assume they failed after all the phthalates outgassed. The problem I have is that I have no idea how old any of the failed tires are. I suspect most of us have not kept complete records. So far, I have had good results with the durability of the red casters that Woodcraft carries, but none of them are older than about 17 years. I have had no failures with them in any size or any caster type. However, today I notice a disturbing development: For the first time, Woodcraft is offering replacement wheels in their most popular size, so there is a good possibility that their oldest wheels are coming to the end of their expected lifetime.
http://www.woodcraft.com/product/161653/3-caster-replacement-wheel.aspx
I also have had no caster tire failures on my cheap, cheap, cheap Horror Freight furniture dollies. They have another problem: No lock washers, so the wheels tend to drop off at very inopportune times.
Other observations that are probably of less use to you in your quest: I have had no failures of Festool Sys-cart casters or OEM casters on Delta welded steel, Powermatic or SawStop machinery or mobile bases.
Re: Good Caster Wheels - edit
Posted the wrong model from McMaster. These take 300lbs each (required on my heavy lathe)
Gary Smyth
Enclosed are several pictures of caster wheels I use for large tools. In my case, table saw, chop saw, jointer, planer, drill press, wood lathe, grinding station, work stand, paint cabinet, and work bench. There is normally a 3/4" plywood base with a plus or minus 1 1/2" square ripped 2 x 4 perimeter fitted to closely enclose the tool base. The caster's steel rectangular base is inset from the base edge so that a rotating caster never exceeds the outer edge of the base. Convenient when sliding the base next to another tool or possibly catching on a toe or cord. On longer bases I use six casters -- at the corners and the center to mostly avoid deflection. I don't need brakes on the casters. The caster used are (relatively) inexpensive one piece solid 2" RUBBER wheels with metal base. Four #8 tapping screws hold each to the base. Never failed on a concrete floor or driveway. I'm guessing 300 lb. capacity each. They are China made. The casters are less than $4 each at any big box. I buy a dozen at a time, about $39, and have them ready. Do not select plastic wheels, get the hard rubber wheels. The larger 4" far more expensive 300lb red wheels failed. I thought I'd try them headed for a slightly rougher surface, but under weight they failed within a week on the same surface the rubber ones work every day. The 2" are harder to move than a larger wheel and are more difficult on cracks in the surface, but they have been reliable for up to twenty years. They are a great investment if you need to change location. On a number of occasions movers move the tool without you having to break it down. For basic short distance mobility of a tool, cabinet or bench -- for me, these work.
I like those Woodcraft ones too... *LINK*
John in NM
I used those on all my home made mobile bases. Nice to know they sell replacement wheels for them too, though mine are still in good shape - oldest set is probably 15 years.
For medium weight casters I always found those to be a good value.
Woodcraft casters
don stephan
Years ago I found here in Cincinnati a local company that specializes in caster wheels for all types of applications from lighter weight dollies to very heavy metal boxes.
They combine wheels, brakes (or not) and mounts for each situation.
Re: Good Caster Wheels *LINK*
walta
I have had good luck with items from the Surplus center. Often the price is less than ¼ of the retail for similar items.
Wow...
John in NM
Lots of good stuff there, casters, motors, chain, gauges.... all the good stuff!
Second yes for Surplus Center
Gary Smyth
Offerings vary quite a bit month by month. Stuff comes and goes. But add to the above -- fans, switches, hydraulic components, gear boxes and bearings, pumps... Nearly 200 page catalog of stuff for fitzzers and noodlers around a farm, shop, or fabricator. Not in latest catalog, but I did buy a squirrel cage fan 120v, 400CFM for under $30 for home made shop air dust collector, and also a replacement lawn tractor seat for $60. You need to be sure of what you want, or work around what they offer to get the result you want, but if you can be sure it'll work, good prices.
