More details
"Could you tell us about your spray setup and details of any thinning or additives you might use in the finish?"
First some background. Decades ago when I began more serious woodworking to build and furnish the house I struggled with finishing. A friend was a tech rep. for a company that supplied finishing component. Part his job was making test panels. When I saw them I wanted to know how to create these finishes and the friend said, "learn to spray".
The finish is Sherwin Williams conversion varnish, post catalyzed. It has a shelf life of years which is why I like it over precatalyzed finish. It is exceptionally durable and looks as good as lacquer or shellac.
I thin it to make it flow better.....as needed, in the range of 20 to 50% of total volume. Xylene when it is hot and toluene (faster evaporating) when it is cold. I spray all year, outdoors.
I spray off a lazy susan so I can spin the piece for optimal presentation. The gun is an ancient JGA 502 with a 43 cap, but 30 is as good or better. I use the 3M PPS cup system because it has so many advantages, reported here some years ago. I never was satisfied with the fiddly parts of getting the HVLP guns to atomize optimally. The JGA is a no brainer and with the PPS cups I can spray even upside down. I could teach someone in minutes to spray simple pieces. Chairs are a challenge.
